Is this normal?
Old Jul 25, 2001 | 07:50 PM
lindseymillar68's Avatar
Is this normal?
I have a 88 Trans Am with tilt steering. Is it normal for the steering wheel/ column to move around up/down, side to side a little? It moves equally in all directions ( about 1/4" at the steering wheel, is there something loose in there, and if so, is it hard to fix? thanks in advance.
Old Jul 25, 2001 | 08:23 PM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Ya, I got an 88 Bird and it did the same thing twice now. I just brought it in the dealer and they fixed it. Dosn't cost that much.
Old Jul 25, 2001 | 09:05 PM
Greg Kuhlmann's Avatar
My 87' T/A does the same thing. How much did they charge, or do you know how to do it?
Old Jul 26, 2001 | 12:46 AM
Diabolical's Avatar
Car: 85 Trans Am WS6
Engine: 305HO L69
my 87 camaro did the same thing, mechanic just had to take the steering column apart and tighten a screw. he said it happens a lot in our cars.
Old Jul 26, 2001 | 08:03 PM
87Irocz's Avatar
Had the same thing happen, turned out that the colum was busted inside mine moved about a 1/4 of an inch too. didnt cost much though
just got a colum from a junked iroc. hope this helps.
Old Jul 26, 2001 | 08:31 PM
Crusader's Avatar
Car: 1988 Firebird Formula
Axle/Gears: 3.45
Thats bad, mine did that. There are like 3 inverse torx bolts that come loose inside. You have to take most of the column appart - took my unlce (who is a mechanic) 3 hours to do the job. Locktighted them and everything so mine's good to go. You want to get that fixed before it gets too bad. Mine was close to having the bolts all they way out It soo nice to have decent steering again.
You should check out the Cascade Crew board, your from our area Yeah, shameless plug I know
Jess
[This message has been edited by Crusader (edited July 26, 2001).]
Fanatic1074
Oct 3, 2022 05:57 AM
Linson
Oct 1, 2015 09:50 PM
Giocio
Oct 1, 2015 12:20 PM
dusterbd
Sep 29, 2015 08:40 AM
BWilcox
Sep 20, 2015 12:19 PM
