Headliner starting to fall...quick fix?
Old Jul 26, 2001 | 02:37 PM
IROCET's Avatar
Car: 88 IROC-Z (Sold)
Engine: 5.7L
My headliner just started to pull away from the backing the other day. It is doing it right in front of where the seat belts go into the roof on both sides. Is there any way to fix this without destroying anything or paying an arm and a leg to fix it? Thanks
Matt
irocet@hotmail.com
drive.to/Stang_Kilr
88 IROC-Z -- 350 L-98, 700R4, Flowmaster, Edelbrock Headers, Catco Cat, K&N, MAF Sceens Removed, Airfoil, March Pullies, Comp Cams Magnum 1.6 Roller Rockers, Bosch Platinum Plugs, Accel 8.8 mm Wires, MSD 6AL, Hypertech Cap & Coil, Hypertech Chip, Hotchkis Strut Tower Brace
Old Jul 26, 2001 | 04:41 PM
Diabolical's Avatar
Car: 85 Trans Am WS6
Engine: 305HO L69
this topic has been beaten to death on this board, check out this post, has a few links for replacing the headliner yourself, it's not very hard, and it's much cheaper than buying a new one
https://www.thirdgen.org/messgboard/...ML/002441.html
Old Jul 26, 2001 | 06:25 PM
fast83camaro's Avatar
Car: 1983 Camaro "SC-350"
Engine: Mild 350 4-bolt
Transmission: 700R4 w/ TCI Stall
take the little bezels around the seatbelts where they go into the headliner off and spray spray adhesive between the fabric and backing then stick the material to the backing.
[This message has been edited by fast83camaro (edited July 26, 2001).]
Old Jul 26, 2001 | 06:29 PM
fast.as.fuc's Avatar
what you should do until you can get it fixed is use thumbtacks the flat one its kinda a ghetto way to do it but it would only be till you could fix it
Old Jul 26, 2001 | 10:34 PM
RARE-ROC-Z's Avatar
where can you buy adhesive spray, i need to get this done before next week, so i am in a hurry.
thanx
Old Jul 27, 2001 | 04:10 AM
Blue_Meanie86SC's Avatar
just do it right, you can use 3M super 77 at most places like wal-mart or home depot and the fabric at must fabric stores or an auto upholstery shop. just make sure you let the adhesive tack up for at least 20 minutes before you apply the foam, otherwise it'll just sag worse.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Golfvette
Aug 24, 2015 06:35 PM
TheJoeY88
Aug 13, 2015 06:51 PM
