ignition lock !!! 1982
Old Jul 29, 2001 | 08:59 AM
lukerene's Avatar
Car: 1982 t top,,z/28,
Engine: 409ci vortec
Transmission: all steel t700r4,1300 stall yahooooooooooo
MY ignition wont turn,,,cant drive the car!!! i pulled the wheel,,,found that stupid lock ring,,depresed the center hub, And removed the indicator gizmo,,thingy,,i noticed the ignition wont turn with the ignition warning buzzer switch in place,,,i took it out,,,ignition turns fine,,put it back in ,,,ignition wont turn,,,i dont think anything is broken,,, although the white plastic nipple was a little worn on the ignition ,,underneath,,,do i need a new ignition and key,,or is the switch the problem,,,the switch looked fairly good,,,although i have no idea what it does,,
Old Jul 29, 2001 | 12:32 PM
MikeInAZ's Avatar
Car: 86 T/A
Engine: 5.0 TPI
http://www.gmtips.com/3rd-degree/dox/tips/misc/key.htm
Old Jul 29, 2001 | 06:28 PM
lukerene's Avatar
YEP, i will use the graphite but i still think i need a new switch, and ignition assembly,,,it is critical,,,
MM2Robinson
Oct 1, 2017 09:16 AM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
Denricci22
Sep 18, 2015 09:02 AM
83 Crossfire TA
Sep 8, 2015 12:06 PM
Jlanz55
Sep 6, 2015 02:35 PM
