Pretty sure my windshield gasket is leaking.
Old May 11, 2013 | 09:31 AM
soul.justice's Avatar
Car: 1985 Firebird Trans Am
Engine: 305 4bbl
Axle/Gears: 3.08
It's been raining a lot here on the weekends so that usually means no working on my car since I don't have a garage I go to mess with my car yesterday and notice about 1/2" of water sitting RIGHT ON TOP of my VIN tag...
The only place I can figure that it's getting in is behind the windshield gasket, especially since it looks like a hack job to begin with. Is there somewhere I can buy new gasket and do it right?
Old May 11, 2013 | 12:02 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
Re: Pretty sure my windshield gasket is leaking.
I'd recommend letting the professionals handle this one -- most windshields break when removing them to change the seal, especially if you're not used to doing them.
Shop around, and expect to replace the windshield if you want to replace the seal. You should be able to get a new windshield installed with a new seal for under $200. Safelite is a good place to start as they are well known, they tend to do good quality work, and they will come to wherever your car is (you don't have to go to their shop). They also match prices if you find a cheaper windshield elsewhere.
Apparently some people on here are having trouble getting the correct outer seal with their new windshield -- a lot of them are coming with universal replacements that are nowhere near close to the originals. Firebird Central has the correct ones for around $10 + shipping http://www.firebirdcentral.com/1985_..._p/wea-252.htm
Old May 11, 2013 | 02:57 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Old May 17, 2013 | 12:45 PM
Billyjoebob007's Avatar
Car: 83 Camaro Z28 (CFI)
Engine: 305 V8 (CFI)
MIne is leaking water in at the top. I pulled up about 2" of that trim and couldnt get it to go back in whatsoever. I called a glass guy i know and he says that that trim has to be installed when windshield is installed.Soo to put in a new piece of trim you have to pay a auto glass shop to basically do a reseal of the windshield. Safelite wanted $80 smakers to do mine LoL , but my glass guy will do it for $20, but i have to meet up with the other side of town somewheres to do it.
Old May 17, 2013 | 03:02 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
The windsield is not sealed with a gasket but rather a bead of urethane.
Like others have said, it's better to let a glass shp do this one. There is a risk of breaking the windshield when removing it. Cured urethane is a PITA to work with and getting it to unseal is difficult, so I am told.
Get it sealed up soon because moisture in the dash area can cause all kinds of other headaches.
Old May 17, 2013 | 08:21 PM
camarotucker's Avatar
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
Old Jun 8, 2013 | 09:10 AM
Engine: 305 4bbl
Axle/Gears: 3.08
I found an independent auto glass guy local to me who said that, worst case scenario, he'd do the gasket and replacement windshield for $210+tax, or $100+ tax if the windshield doesn't break when he pulls it. Does that sound about right?
What about my pinch welds? Do i need to be worried?
Old Jun 8, 2013 | 05:22 PM
mantaguy's Avatar
Engine: 5.0 EFI
That's not a bad price,just expect to pay the $210+Tx.That windshield is most likely going to crack after 28 yrs,mine did,but I didn't care I had already ordered it.The guy came to the house and did the job.
db057
Apr 28, 2019 07:45 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
TheExaminer
Sep 6, 2015 11:40 PM
Victor6
Aug 30, 2015 02:09 AM
