swapping clusters
Old Aug 8, 2001 | 07:52 AM
82suped-up-coupe's Avatar
swapping clusters
I have an 82 camaro that was originally a 2.8(now a 355)
does anyone know what clusters are a direct bolt in, I have the 85mph spedo and no tach right now and it pisses me of every time I look at them
thanx in advance
Rich
www.angelfire.com/ri/camarogarage
Old Aug 8, 2001 | 10:18 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Up to a 90 (or 89,, I forget) should swap in no problem (just plug the cluster in). However, if you have the idiot lights (which I'm guessing you do w/the no tach thing), you will need the proper sensors to make the gauges work (like the bell shaped oil press sensor & the temp sensor). A warning too,, the replacement Temp. sensors are very inaccurate (reading way high), if poss. get an OEM sensor from a TPI car from a junkyard, they aren't true either,, but way closer to 'true' temp. Assuming the ECM is gone as well, I'm not awfully sure how you would get the tach to work right, mine just worked when I plugged it into my camaro.
The mind is like a parachute, it only works when its open
Old Aug 9, 2001 | 06:57 AM
thanks
Jeremys87
Jul 14, 2022 09:08 PM
Eric2ndGen
Nov 5, 2015 01:51 PM
Bstrang6
Sep 8, 2015 04:29 PM
355sbcTPI
Aug 19, 2015 04:38 PM
ChevyZ71
Aug 13, 2015 07:30 AM
