Removing aero spoiler clips. How???
Old Aug 8, 2001 | 08:43 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I just took off the aerospoiler on my GTA. Now, how do I remove the clips that hold the front of it on? Are they just glued down?
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Aug 8, 2001 | 10:05 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
The clips that are on the band around the back glass are held by spot welds. You can see small divits where the welds are usually. Take an 1/8" drill bit & drill just a little less than the thickness of the clip. After you can take a pair od pliars & work the clip back & forth, the weld metal will eventually fatigue & break free. Then file the spots down, fill with glazing putty if needed (from the drill bit divit), & paint.
Hope that helps
The mind is like a parachute, it only works when its open
Old Aug 9, 2001 | 07:31 AM
Jim85IROC's Avatar
What a pain in the *** .
Thanks for the info though. I was too damned hot last night to screw with it so I figured I'd post the question here to get a head start.
The IROC Homepage
Custom Thirdgen Subwoofer Enclosures
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
TheExaminer
Sep 28, 2015 02:28 PM
Eric-86sc
Sep 7, 2015 02:10 PM
