power mirror moves left and right, but not up and down?
Old Aug 13, 2001 | 01:40 AM
Kandied91z's Avatar
please give me some ideas; i've checked the wiring and everything is connected as well as the insulation on the wires is in tact.
Old Aug 13, 2001 | 08:40 AM
custman87T/A's Avatar
Mine did the same thing till I noticed if the switch was out of the console the mirrors worked perfectly. It is only when mounted that it happened. I took a dremel to the mounting hole around the mirror switch to loosen it up and now it works. Pull the switch out and try it. Check the wires for continuity from the connector on the mirror to the switch one might be broken. Put 12volts to each of the wires in the connector on the mirror and see if it moves like it should. My guess is its a bad switch.
Old Aug 13, 2001 | 01:48 PM
Mo's Avatar
Mo
What about the little cross thing that holds the mirror, one of the pieces on that cross broke on mine and it would move only move up and down.
Old Aug 13, 2001 | 02:50 PM
MikeZ28's Avatar
Car: 92 Z28 Z03
Transmission: 700-R4
Axle/Gears: 2.73 G80
mine did the same thing. try and push it on a digonal on the way u want it to go. play with it for a couple of mintues it might work. cause mine did.
86 Z28:
L98 350
aluminum heads
T-5
235/60R15 BFgoodriches
dual 3"flowmaster exhaust
20% tint
hatch wing
2 12"kicker solos
300 watt Sony xplod amp
Sony xplod deck
K&N air filter
http://www.geocities.com/xmikex.rm/mike.html
Old Aug 14, 2001 | 08:22 AM
USA-1's Avatar
Car: 1987 Iroc Z "Classic Roc"
Engine: 5.7 350
I had the same problem. In my case, the contacts were pretty nasty looking. I cleaned them up and it worked fine. When I finally put the swith back together I broke it reinstalling it (what a doofus!). Check the contacts.
You don't have to wear a tuxedo to sport a bowtie!
Some pictures of my mess in progress.
http://www.geocities.com/Jamie_Caruvana/
jaridjohn
Jul 8, 2024 03:49 PM
1992 Trans Am
May 10, 2023 07:19 PM
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
AkDrifted
Aug 17, 2015 07:45 PM
novaderrik
Aug 10, 2015 12:44 PM
