a/c vents non functional......
Old Aug 12, 2001 | 09:11 PM
Rice_Cooker_'88's Avatar
just like it says, my a/c and heater vents don't work. they haven't since i got the car. the heater and ac work but the only vent that works is the front defroster vent on the dashboard. anyone know why this is and how it can be fixed? thanx
'88 CAMARO 305
OPEN AIR ELEMENT
FLOWMASTER CAT BACK EXHAUST
COMPUTER CHIP
HYPERTECH 160* THERMO.
Old Aug 13, 2001 | 05:02 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
This is a fairly common problem with our cars. Search the archives, and you'll no doubt come up with the required info.
JamesC
Old Aug 13, 2001 | 08:43 PM
sorry. couldn't find anything there. can you guys help?
Old Aug 13, 2001 | 08:58 PM
mcconahay37's Avatar
There should be a vacume canister on the driver's side of the firewall in the engine compartment with 2 vacume lines going into it. It's about 6 inches long and about 3" around. The upper vacume line goes to your HVAC controls and the lower line draws vacume. Play around with the vacume sources until it works. Mine was messed up, so I just connected the upper line straight to vacume off of my intake. If this doesn't help, do a search on the tech board for HVAC or ac controls
82 Camaro:
350
Erson cam, ported heads,Comp Cams 1.6:1 rocker arms
Edelbrock Performer RPM intake, Holley 600
Crane Hi-6 ignition, Accel supercoil
TH350 tranny with 2500 stall.
Eibach Pro Kit
SLP 1 3/4" headers
Old Aug 13, 2001 | 09:59 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
Have you tried looking under the dash for the vent shafts that lead to the middle of the dash.They are black and look like square tubes.
Old Aug 14, 2001 | 01:16 PM
Defrost is the default setting if no vacume signal is supplied.
Old Aug 14, 2001 | 02:19 PM
i looked for the canister on the firewall and didn't see it. I saw something that resembled the description that was under the wiper motor but there were no vacuum fittings.
Old Aug 14, 2001 | 02:49 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Chances are the HVAC control broke itself.
Best fix is go to a junkyard & get a 'new' one for around $5-10. The vents are controlled by a vacuum diverter valve/switch on the backside of the HVAC controls.
The floor vent is the 'default' if the controls are off.
The mind is like a parachute, it only works when its open
Old Aug 14, 2001 | 10:08 PM
thanx for the input guys. is there a way to tell if the one i get from a junkyard is good or do i have to take my chances?
Pac J
May 17, 2020 10:44 AM
jrdturbo
Mar 31, 2016 02:58 PM
2012sergen11
Oct 13, 2015 07:38 PM
Fanatic1074
Oct 2, 2015 03:47 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
