New Gauge cluster - odometer
Old Aug 17, 2001 | 01:00 PM
viperwsu's Avatar
Car: 91 Camaro RS
I am swapping a 350tpi into my '91 rs, and I want to swap in a 145mph cluster as well. The problem is, my RS only has 70k miles on it, according to the 110 cluster, and all the 145 clusters I have found show 100K or more. Is there any easy (and legal) way to roll the 145's odometer back to match my 110? Thanks!
Old Aug 17, 2001 | 01:25 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I am not sure if Camaros are the same as my Firebird, but if you take apart your speedos, the Odometer is controlled by a little motor. You should be able to remove the Odometer and swap it over, make sure the only thing you are using is the old odometer. Use the 145 motor, circut board etc. Just start saking screws out, it should be self explanitory.
John
RS Reaper
Oct 17, 2018 07:52 PM
Luigytico09
Oct 1, 2015 08:46 AM
Gordonr1973
Sep 29, 2015 11:59 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
