Automatic shifter knob change???
Old Aug 13, 2001 | 08:28 PM
IROCME's Avatar
Car: 1986 IROCZ
Engine: LB9....rebuilding coming soon
Transmission: rebuilt 700R4
Automatic shifter **** change???
Ok,I got an 86 IROC with the black leather baseball shifter,I was wondering if I happened upon a 91-92 camaro in a junkyard how hard would it be yo change the shifter??I'm talking about autos,the top part with the button you push down,what tools are needed for this swap??Is it hard???
Drive it like you stole it
Old Aug 13, 2001 | 08:55 PM
REZN8R's Avatar
Car: '96 M3
Engine: 3.2L V-6
Transmission: 5-sp
I've got a '91 RS that I took the stock shifter out of to replace with an aftermarket one. All it took to get it out was a screwdriver. There's a little U clip in the front of it. I don't know how yours is held on though. E-mail me if your interested in my stock one.
Old Aug 13, 2001 | 09:06 PM
IROCME's Avatar
Car: 1986 IROCZ
email me a www.mmikanowicz@yahoo.com
Old Aug 13, 2001 | 11:01 PM
Blue_Meanie86SC's Avatar
for your current one, just give it a good tug, if that doesn't work pull out the button and you'll see a c-clip, take that off and then pull the **** off. In order to upgrade to the new *****, you'll need to replace the whole shifter assembly, it's about 4 bolts and a couple cables. should be a direct swap.
Old Aug 15, 2001 | 08:29 PM
Tyler-88's Avatar
does anyone have a url to some NICE auto shifter *****. i seen two so far, their like a T handle with the push button on the left side of the T. only problem was that it came in wood grain or carbon fiber..ewww
Old Aug 17, 2001 | 11:42 PM
David Culpepper's Avatar
I put a Carbon Fiber/Billet shift **** on mine. I got it from one of the local speed shops. It is actually made for a r!ce burner but it looks cool on our cars. It has set screws that hold it on. I will see if I can snap a pic and post it.
Old Aug 20, 2001 | 07:23 AM
87 Firebird's Avatar
Why not use the auto shifter from some of the newer GM models? IIRC, they should all fit up, or only require some minor tooling to accomplish the fit. I'll go look up some part numbers at work today, and get back to you guys tonite.
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
camaro11j
Sep 19, 2018 08:49 AM
deracer
Apr 11, 2016 12:04 AM
NBrehm
Aug 25, 2015 11:49 PM
