Jamming different than body color
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
On a car getting a black interior, but a different exterior color (like red or yellow or orange), would jamming it black look weird ?
I've always done flat black frame and engine bays and that was always acceptable. I'm curious about jamming the car to match the interior and spraying the body a different color.
-- Joe
-- Joe
Re: Jamming different than body color
It's your car, matters not what others think. If you like it go for it. If you ask my opinion, I say it wouldnt look right. You would have a strange break in the colors on the jam where the quarters meet it. Totally stripped everything off my car for paint cuz I did a color change. PITA but nothing done right is easy
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I was thinking of two-tone orange and black, black behind on the bottom and other accents. But was wondering about jamming it black too..
-- Joe
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
I would definitely paint the jams the same color as the car .
I'd just be afraid it would look like a poorly done color change. You have too much effort in it to let that even be a passing thought when you have a door open at a gas station or something lol.
I think Joe hit the nail on the head there. When you see jambs painted a different color it looks like a poorly done color change, which is clearly NOT what you doing. Sounds like you'll have a hell of a car when you're done
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
That's kinda what I figured. Will jam it the same as the exterior color.
Thanks guys!
Will post pictures once it's done.
-- Joe
Thanks guys!
-- Joe
Car: 91 Z28
Axle/Gears: Stock
Run your two tone break line through the jamb. Huge PITA, but it looks good and gives you what you're looking for, if the bottom color is black that is.
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
I would stick with body color as well for the above reasons. If you want some extra pop on the jambs, pinstripe might work or color LED accents that maybe make the jambs look a different color when lit. The problem with highlighting jambs or door edges is that those areas aren't usually visually appealing ( latches and hinges) so you don't want to attract the eye to it.
Engine: LS1, LB9, L03
To me, different color door jambs are the biggest giveaway that a car has had a backyard rattle can color change, which is a HUGE turnoff for me. Leave them body color.
1Aauto
Sponsored Vendors
Aug 24, 2015 03:40 PM
LT1Formula
Aug 20, 2015 09:36 PM
