Aluminum console
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
check out mine
1991 banditt2 #130 of 600
Project 350 TPI Banditt II
http://www.street-dawg-racing.cityslide.com
http://discussion-board.com/GreaterC...dyAssociation/
http://www.cincyspeed.com/
Engine: 5.7 HSR
Banditt2 is an appearence package put on 600 firebirds in 1991.the alum. over the gauges was put there by the company who put the Banditt 2 package on.it runs down over the whole center console
I have a sheet of aluminum 24" x 48". If I have to I will try to make my own, but I have no experience with sheet metal work.
I'm hoping that there is a company out there somewhere that makes aluminum consoles for 3rd gens. I don't mind the plastic instrument panel/dashboard, but a console should be made out of metal.
k thanks Ill go get myself a few square feet to mess with. I been meaning to start playing with metal and making things like shift plates, consoles etc.
Havent figured a good way to bend it yet other than the table vice and a few clamps lol
Car: 91 Trans Am Convertible
Engine: 300 HP 350 CI
Axle/Gears: Drums?
This is a little far out there, but if anyone can find a fabrication shop or somewhere similiar with a laser cutting machine then you could probably give them a template of what you need and get them to cut it. I know this sounds expensive, but if you got a lot of them done in bulk the cost per part goes down, and then you can turn around and sell for a profit. I work in a fabrication shop and we only have a plasma cutting machine which damages the metal too much. They could be polished or left raw, or even anodized in different colors.
keep in mind aluminum interior parts get REALLY hot in the sun. i know Fl. can be worse than most places, but we once had a pro street... well maybe i shouldn't say (*******). but it had an entirely stripped out interior w/ all aluminum pieces and nothing in it could be touched if it sat in the sun for just a few mins.
I guess I didn't mention it in my original post, but I don't intend to leave the console
in bare aluminum. The aluminum would be upholstered or covered in carpet. I just want something under the upholstery that will be stronger than plastic. The only thing that won't be covered will be a shift gate.
Axle/Gears: 3.45, 3.27, 3.27
Since you are going to cover it, it doesn't have to be perfect. You should be able to fab it yourself with hole saws, hack saw, files, bench vise. You know, the common garage tools. Rivet the corners with a reinforcement behind it. Epoxy works good as an assy method. Wood or metal angle steel pieces can ba used for the mounting tabs to secure it to the floor and dash. 3M Super 77 adhesive to adhere the carpeting. Nothing exotic or complicated about it. If you need help, let me know. I thought you were referring to aluminum panels with the machined swirl mark pattern to it, which would be more difficult. McMaster-Carr is in Sfe Springs and can supply most all of what you need (562)692-5911 http://www.mcmaster.com/.
90 RS Convertible
Owner: Top-Down Solutions
http://www.sc3gfb.org/members/lonsal.html
http://www.taskerinc.com/gs3/profiles/Lon_profile.htm
90 RS Convertible
All you need is some thin pieces of Aluminum and a dremel
un4givin89
1989 Camaro Ralley Sport, 305 TBI 5 Liter v8
Project List:
Crate 383 Engine
Flowmaster Exhaust
New Tires
Windows tinted
Interior swapped for two tone colors
Lowering Springs
Sound System
www.mikekey.net
un4givin89
Project List:
Crate 383 Engine
Flowmaster Exhaust
New Tires
Windows tinted
Lowering Springs
Sound System
www.mikekey.net
