145mph speedo on 92 RS
Old Aug 31, 2001 | 08:05 AM
92RSGUY's Avatar
I just received a 145mph speedo for my 92 RS. I would like to know if I need to change anything out before replacing my 115mph with this new one. I read some old posts on this subject, but I couldn't find one on a 91-92 camaro. Thanks.
Old Aug 31, 2001 | 08:46 AM
jtmiller92's Avatar
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
I just did the 115 to 145 speedo swap in my 92RS 2 days ago.It really is a direct swap,pull the other one out and put the new one in....Before you actually bolt everything back up though,i suggest that you turn your lights on to make sure none of the lights are blown on it.when i put mine in one of the speedo lights was out.
92RS
Old Aug 31, 2001 | 09:46 AM
92RSGUY's Avatar
Thanks for the info!
Old Aug 31, 2001 | 09:49 AM
FiReBReTHa's Avatar
k, so its just same harness plugging. and i can use any years?
what about 'speedo gears' for tire size...?
for a 91 firebird
91 FireBird 305 V-8
Edelbrock Catback, Custom Alarm. Fourth Gen Console. i have six cupholders. all for starbucks!
Go|)Created The Earth, And Then Turned Up The Bass.
Here's My Audio Install!
"Honda's FOR ME TO POOP ON!" -Triumph...
Old Aug 31, 2001 | 03:56 PM
jtmiller92's Avatar
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
Firebretha,I'm not sure about the firebirds.For the camaro all 90-92 guage clusters will interchange,as far as gears go the cluster won't have anything to do with that.....
Old Aug 31, 2001 | 05:53 PM
Chevy83Z28's Avatar
what about the odometer, is it built into the speedometer or can you change just the speedo and keep the odometer? i dont wanna start messing around with the mileage on my car (83 z28) in case i ever have to sell it, but i wanna switch out speedo's to get rid of the 85 mph from factory. thanks guys.
Old Sep 1, 2001 | 10:15 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
ttt
Old Sep 2, 2001 | 05:01 AM
jtmiller92's Avatar
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
Chevy83Z28,If you have the confidence to get into the cluster like that its definately possible to 1)roll the odometer to the mileage you want or 2)just swap the two odometers out..me personally..i'm not going into it,there a lot of small parts in there and I don't have the patience.You can also check into a few shops that repair speedometers...i'm sure they can do it.
Old Sep 2, 2001 | 07:18 PM
Chevy83Z28's Avatar
thanks jtmiller, i was hoping it would be just two tiny screws that hold the entire odometer housing to the speedometer. i guess my best bet is to just check out these swap meets and see what's involved before i go 'hacking hehe .
Old Jan 7, 2005 | 09:54 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
hey JT.....did you just swap the speedos or the entire gauge cluster??? im guessing the entire gauge cluster
Old Jan 8, 2005 | 02:22 AM
911rsq's Avatar
Car: '91 Z28 & '90 RS Vert & '89 RS
Engine: 5.7L & none & 2.8L (soon to be LSX)
Transmission: yes
Axle/Gears: One's with teeeeefs
For those of you swapping out your 115's for the 145's, this is only a plug and play operation if your car has a V8 from the factory. If you have a V6 car the tach is gonna be off, as it was set to check on 6 cyl instead of 8.
Old Jan 8, 2005 | 02:35 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
but what im confused on is if the plug and play operation is strickly for the entire gauge cluster or for just the speedo as well?
does anyone have a side by side shot of the 115 and 145 speedos by any chance???
Old Jan 8, 2005 | 09:23 AM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
If you have a 90-92 V8 Camaro, than the 90-92 145 MPH gauge cluster is a direct swap, everything will swap over and work correctly.
Old Jan 8, 2005 | 11:33 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
we (I) now are aware the entire cluster will swap fine but if i get ahold of just the speedo and swap it in does it then need to be calibrated?
Old Jan 9, 2005 | 11:38 AM
DTL504's Avatar
Car: 84 Z28 Convertible 2 Seater
Engine: Dart Little-M SBC 400
Transmission: Pro-built Automatics 700R4
Axle/Gears: Strange Engineering 3:73
My tach was reading 2500 with the 145 speedo at idle when she normally idles at 950. I just did the swap on my 84 Camaro, I had to take my old tach out of the 85mph speedo and put it in the 145 speedo, problem solved. Just remove the two little screws and swap tach. Reverse direction to install in the other cluster.
Old Feb 11, 2005 | 06:07 AM
bombader's Avatar
Car: 1989 Camaro IROC Z-28
Engine: 2002 LS1
Axle/Gears: 3.08
What about the TA's mine has the lame *** 85mph speedo will a 145 unit be a direct swap? (From another TA of course!) A local yard has like 4 of them. Or will I have to get the 120 unit?
Old Feb 11, 2005 | 10:25 AM
DTL504's Avatar
Same, Same
GTAman
Jul 3, 2024 07:29 PM
Elephantismo
Feb 13, 2019 12:51 AM
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
TrevinE
Sep 14, 2015 03:20 PM
