Hatch Question
Hatch Question
Can the sheet metal portion of the hatch be easily seperated from the glass portion? If so how. Just curious if anyone else has done this. See if there is an easy way to do it before I go ripping into mine.
'86 Camaro SC 2.8 V6, 5spd, T-Tops
Mods:
(Performance)
Flowmaster cat back exhaust
(Non-Performance)
Pioneer DEH-P4000 CD receiver head unit
Pioneer 6X9 Tri-Ax speakers
Jensen 8" dual voice coil sub
Blacked out tail lights and side markers (VHT
Nightshades spray tint)
Mods:
(Performance)
(Non-Performance)
Yes--there's bolts on the bottom--where the metal and glass meet. There's maybe 4 bolts--been awhile but just start taking apart the plastic trim and you'll see what I'm talking about.
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
You will also have to take a puddy knife to slip between the glass and hatch to release the black goo.
When I put one back together I used 100% Silicone (NOT LATEX SILICONE). goop it in and smmthe it out where it shows. you might even want to get some strip caulk. It comes in a box and is black, you take it out 10" strip by 10" strip. neet stuf to work with. Keep in mind it gets your hads gooie.
John
I think I used the word "goo" twice in this post. I am not sure but that may be the first time ever on-line I have ever used the word "goo".
87 Formula Yellow/Black
5.1 TPI Automatic
Baer 12" brakes 4 wheels, KYB AGX Adjustable Shocks & struts, Custom Leather interior, WAAAY TOO MANY MODS TO LIST
87 Formula TPI (5 Speed) Yellow/Gray STOCK
1967 Buick Riviera 430hp Turns high 14's (Not bad for 4300 lbs)
83 Camaro (Parts)
83 T/A (parts)
http://www.3rdgenformula.com
John
5.1 TPI Automatic
83 Camaro (Parts)
83 T/A (parts)
