Custom Dash
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Custom Dash
I am thinking about making my own dash, anyone done a project like this???
I want to make it look like a Ferrari. Just sounds like a neat experience.
John
87 Formula Yellow/Black
5.1 TPI Automatic
Baer 12" brakes 4 wheels, KYB AGX Adjustable Shocks & struts, Custom Leather interior, WAAAY TOO MANY MODS TO LIST
87 Formula TPI (5 Speed) Yellow/Gray STOCK
1967 Buick Riviera 430hp Turns high 14's (Not bad for 4300 lbs)
83 Camaro (Parts)
83 T/A (parts)
http://www.3rdgenformula.com
John
5.1 TPI Automatic
83 Camaro (Parts)
83 T/A (parts)
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Unless you're a fiberglass wizzard, I'd be willing to bet your results would be less than anticipated.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
Custom Thirdgen Subwoofer Enclosures
"I didn't know a bored out Ford could go so slow" -Shenandoah
The IROC Homepage
Anything is possible, been around Fiberglass for many years now, Just sounds like fun..
Why be Like everyone else...
I might even be able to produce the pieces...
The company that I work for makes windshields and windows for a guy that races INDY or FORMULA 1, he used to Gace GTP, anyway, he does alot of his own fiberglass work for several cars.
The secret is to take your time and do it right.
John
John
Actually I am thinking of using a fiberglass/Steel frame with a "Great Stuff" foam padding. I would cover it all in vynal.
John
John
I think your on to something. Make a dash so custom guages would look normal in it. I wouldn't use great stuff foam though. I've heard of a company that recovers muscle car dashes and I'm sure they could wrap the dash for you. It was an article in a chevy mag on it.
Car: Trans Am
okfoz,
If you do it, show progress with pics, as I don't like the third gen dash at all and would be interested in your idea. OR, you could recreate the 4th gen dash to 3rd gen dimensions and make quite a few dollars.
http://www.caraudioresources.net/installs.shtml Has a camaro with a custom dash. Might be good for some ideas. its the last third gen camaro on the list from spring break nats 2000.
91 Z-28 Coupe
L-98, 700-r4
Borla cat back
Performance Resource chip
Centerline wheels
K&N, Gutted air boxes
Gutted cats
Best Pass = 13.710 @100
Best 60' = 1.842
on M/T Sportsman Pros
Race Car:
S/P 91 Camaro Z/28
454 LS7 crate motor
Crane Roler cam
Dart intake
1000cfm TRC Carb
Powerglide
9" Ford rear
Goodyear 14"-32"-15"
Weld prostars
All steal except for hood and rear deck
Best ET: 9.64 @ 145
3000# with driver
91 Z-28 Coupe
L-98, 700-r4
Borla cat back
Centerline wheels
Gutted cats
Best 60' = 1.842
Race Car:
S/P 91 Camaro Z/28
454 LS7 crate motor
Crane Roler cam
Dart intake
1000cfm TRC Carb
Powerglide
9" Ford rear
Weld prostars
Best ET: 9.64 @ 145
3000# with driver
Bad Blk Z,
Thanks for the link. I found it to be interesting, and informitive. I personally was thinking about something a litle more like the following pix:
http://www.usol.com/~okfoz/Ferrari/5...teriorDash.jpg
http://www.usol.com/~okfoz/Ferrari/5...teriorside.jpg
http://www.usol.com/~okfoz/Ferrari/detail_interior.jpg
[This message has been edited by okfoz (edited September 05, 2001).]
Car: 1992 RS
Engine: 406 Stealth Ram
That is one fine looking interior. I suppose it could be done, but its going to take A LOT of fiberglass and A LOT of time. If you try this, be sure to show pics of your progress.
Sure thing, I am also thinking about making Ferrari Style front & rear faias, Hood & tailights to bolt in
John
John
Car: 1986 Z28
Engine: 355
Transmission: th400
I didnt' create a whole new dashboard, i just redid the gauge cluster.
I used lexan glass instead of the pastic smoked it gunmetal grey, changed the layout some, and put a gauge pod on the A-pillar, so far so good, soon we'll see if they work
It's always SOMETHING
Car: 1992 RS
Does anyone have any more pics of the Ferrari dash? I need to see some moe detail, especially behind the steering wheel to the left. Thanks.
Update - I found a few:
http://www.barchetta.cc/Common/Image...hboard.red.jpg
http://www.barchetta.cc/Common/Image...terior.red.jpg
http://a332.g.akamai.net/f/332/936/1...te.int.350.jpg
[This message has been edited by Scott_92RS (edited September 06, 2001).]
