87 Iroc fog light spring-EDIT:found p/ns inside should someone need them
Old Jul 4, 2013 | 09:32 PM
Green89IROC305's Avatar
Car: 91 Z28 - using 87 electricals
Engine: 383 HSR EBL
Transmission: 700R4 - Stage 3 Fixed Pressure
Axle/Gears: GM 3.08 POSI
Anyone know where to get the spring that puts tension on the light. I had the aiming threads break loose while driving and the spring went with it.
Also any recommendations on which aiming kit to use. The motormite one I got is made of cheap plastic and the threads strip constantly in these.
Old Jul 5, 2013 | 09:08 PM
Engine: 383 HSR EBL
Re: 87 Iroc fog light spring
Well I tracked down the gm part numbers for the springs,bolts,nuts to retain and aim the fog lights.
spring:16506443
retaining nuts:362379
Bolts: 16506418 or 14080486
The bolts have 2 different parts, they are both listed as parts for an 87, I am trying to track down a part picture of them but no luck.
Hope this can help someone.
jaridjohn
Jul 8, 2024 03:49 PM
1992 Trans Am
May 10, 2023 07:19 PM
mustangman65_79
Aug 12, 2015 06:39 AM
mustangman65_79
Aug 11, 2015 03:17 PM
Omega
Aug 10, 2015 12:46 PM
