gas tank door remove
Old Sep 18, 2001 | 11:05 PM
NyphoFor6hrs's Avatar
i am shaving the door handles side markers and the anntina off my car and was wanting to also shave the gas tank door off i was thinking about putting the filler neck in the storage carpment in the trunk on the driver side i was wanting is this possible or will i get fumes in the car and if so could i put a vent tube out if it to vent the gasses out side thnx for the help
Old Sep 18, 2001 | 11:36 PM
maksik7's Avatar
Yea I'm pretty sure you'll get plenty of fumes inside. My question is why? I just don't hink it'll be worth the effort. Its you car but I just don't see any reason to do it...
On the other hand you could pull up to the gas station, sit in the car, and watch the gas station attendant frantically search for the gas door
Old Sep 19, 2001 | 12:23 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
There was actually a quite lengthly & somwhat detailed discussion about this a little while back on either this boad or the appeareance & detaliling board,, do a search for it, you might find some answers to your question.
The mind is like a parachute, it only works when its open
Old Sep 19, 2001 | 03:59 PM
thnx for the help with the old topic they had someone metion what i was thinking about the filler neck in the storage compartment but i still dont know what to do about fumes. the reason i am wantig to do this i want something diffrent so when i go to the shows
Old Sep 19, 2001 | 04:54 PM
89 Iroc's Avatar
This kid i know in Philly build lowriders and he put the gas tank filler neck in the wheel well of his pick up.
Old Sep 19, 2001 | 05:43 PM
Thirdgenfbody.com's Avatar
I saw a full size chevy truck with the filler inside the bed,
and a blader with it behind the taillight, and one with it in the wheel well.
the one i saw in the wheel well, had a door that opened and a piece swung out to hold the filler nozzle, their was aflexible hose going to the filler neck... dunno what it was made of.. but when it was closed you couldnt tell it was their.
1985 IROC Resto underway
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
mustangman65_79
Sep 1, 2015 03:51 PM
AkDrifted
Aug 17, 2015 07:45 PM
kyleb24
Aug 15, 2015 08:24 AM
