window relays
Old Aug 5, 2013 | 04:50 PM
NO990's Avatar
Car: 1991
Transmission: manual
Axle/Gears: 2/.65
window relays
Where are the power window relays located in a 91 Camaro?
Old Aug 10, 2013 | 04:06 PM
livewire's Avatar
Car: 1983 Z/28
Engine: Edelbrock 355
Axle/Gears: 3.42/Zexel/PBR
Re: window relays
Iirc they are behind the drivers kick panel.
Old Aug 11, 2013 | 06:53 AM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
Re: window relays
i don't think camaros have relays.otherwise the windows wouldn't be so slow.
Old Aug 11, 2013 | 10:39 AM
Aaron_SK's Avatar
Car: 1985 Sport Coupe
Engine: 3800 Series II Turbo
Transmission: 4th-gen WC T5
Axle/Gears: 3.27 BW Limited
Re: window relays
You are giving GM's electrical engineers far more credit than they deserve.
Zenish is correct, here are no window relays. They are fed directly from the switches.
Regardless, installing a relay bank is a good idea. The motor switches are SS so you have to use five-wire relays and ground the closed pin, but it's not hard to do.
PurelyPMD
May 5, 2016 04:57 PM
jrdturbo
Mar 31, 2016 02:58 PM
lanceflame44
Sep 25, 2015 12:28 PM
gta892000
Sep 16, 2015 12:37 AM
Fronzizzle
Sep 8, 2015 12:10 PM
