door latch plastic?
Old Aug 7, 2013 | 04:19 PM
haro_is_king's Avatar
Car: 1989 camaro iroc-z
Engine: L98 350 5.7 bored 0.30 over
Transmission: 2400 stall lockout
door latch plastic?
does anyone know if the plastic piece that covers the latch and makes contact with the striker can be replaced or does the whole latch need to be replaced? have a small rattle and the plastic is worn , resulting in the metal to metal. thanks
Old Aug 7, 2013 | 04:39 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
Re: door latch plastic?
Unbolt the striker. cover with heat shrink tubing. and reinstall.
is a snap fix
Old Aug 7, 2013 | 06:53 PM
that is an ingenious fix my man! depot or lowes to pick up the tubing ? i have a heat gun. thanks again........bye bye rattles
Old Aug 8, 2013 | 07:02 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Check posts #16 and #17 for a permanent fix:
https://www.thirdgen.org/forums/body...servation.html
JamesC
Old Aug 9, 2013 | 12:32 AM
most the time you can get the heat shrink tubing on without removing the striker.
and just use the heat gun to get it tight. you can get it in DK blue/red/white/black
Old Aug 9, 2013 | 08:33 AM
Thanx james and whiteZ, appreciate the help!
Old Aug 9, 2013 | 03:26 PM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
James: I tried your trick years ago. I sourced those back seat plastic GM striker covers and I couldn't get it on at all. Maybe I didn't do it right back then (was probably in 08-09). Any tips on how to get it on?
Old Aug 9, 2013 | 04:03 PM
JamesC's Avatar
The rear seat striker and the door striker are the same size. I simply cut the plastic and pushed it on. No issues or headaches that I recall.
JamesC
Old Aug 9, 2013 | 04:24 PM
Which part of the plastic did you cut off? The large round part?
Old Aug 9, 2013 | 08:38 PM
JamesC's Avatar
Yes. Pics in the link I provide above.
JamesC
Old Aug 12, 2013 | 09:44 PM
hey james thanks again, i used your method after the shrink tubing i picked up from lowes was too small/big (should have just went to an auto store) and it worked like a charm......many thanks boss
Attached Thumbnails door latch plastic?-imag0538.jpg   door latch plastic?-imag0683.jpg
tglennon11
Sep 23, 2015 05:30 PM
billybob6110
Sep 23, 2015 01:30 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
tsfso59
Exterior Parts Wanted
Sep 9, 2015 09:09 AM
NiG
Sep 7, 2015 11:25 PM
