What's the trick to fool the hatch motor to come back up?
Old Aug 10, 2013 | 02:20 PM
syc0path's Avatar
Car: '88 Trans Am
Engine: 305 TBI
My sister has an '86 IROC, and the hatch won't latch shut. On both her car and my '88 Trans Am, we've had situations in the past when u put the hatch down very lightly, and it's enough to activate the hatch motor to go down but NOT enough for the hatch motor to actually latch. In other words, the motor is in the down position but it's not latched to the hatch.
I know there's some way to trick the hatch motor into coming back up. But I haven't done this on my car in years, so I don't remember the trick. What is it??
Old Aug 10, 2013 | 02:56 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
Re: What's the trick to fool the hatch motor to come back up?
IIRC, there's a tab sticking out somewhere on the motor that you have to trip with the end of a screwdriver, and then the motor will come back up. You'll need to remove the plastic trim panel that covers the motor to get to it.
Old Aug 10, 2013 | 04:09 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
You don't need to remove anything... There is a little lever on the left side of the latch mechanism when you are looking at it from the back. Push it down with your finger and hold it until the motor assembly bottoms out and the reverse switch trips. Let go again and the motor assembly comes back up.
This is if both the latch switch and the reversing switch are good.
Then adjust the latch.
Old Aug 25, 2013 | 06:00 PM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
What he said ^^^ .. but the switch is just a switch, don't expect a spring to trip or anything. and it's kinda in the center of the latch where the receiving latch on the hatch would lay..
Old Aug 25, 2013 | 08:49 PM
cdoyle's Avatar
On mine, the motor will sometimes overheats. So if I just disconnect the battery for awhile, and reconnect it. The motor will come back up.
madsv1000
Aug 20, 2015 06:45 AM
stalkier
Aug 13, 2015 12:59 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
1nastygta
Aug 8, 2015 07:38 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
