Help Door WON'T Close
Old Sep 30, 2001 | 03:15 AM
AZ88Maro's Avatar
Ok i go to shut the door and it just slams into the car and bounces open. I think the latch on the door that grabes the bolt on the car is broken, anyone have this happen before? How do i fix it? Need help quick! Thanks Bobby.
Old Sep 30, 2001 | 03:42 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Yes, it happenes on more than just 3rd gens. Lift on the handle & pull the latch (that hits the striker) in the door down, or maybe up (I forget),, it hasn't happened to me in awhile. It will move to where you need it though by messing w/it while lifting on the handle.
The mind is like a parachute, it only works when its open
[This message has been edited by deadbird (edited September 30, 2001).]
Old Oct 1, 2001 | 04:05 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I usually stuff a screwdriver in the latch and pull out as I am pulling on the handle to release the latch. Been a while since it has happened to me.
John
G O D BLESS AMERICA
87 Formula Yellow/Black
5.1 TPI Automatic
Baer 12" brakes 4 wheels, KYB AGX Adjustable Shocks & struts, Custom Leather interior, WAAAY TOO MANY MODS TO LIST
87 Formula TPI (5 Speed) Yellow/Gray STOCK
1967 Buick Riviera 430hp Turns high 14's (Not bad for 4300 lbs)
83 Camaro (Parts)
83 T/A (parts)
http://www.3rdgenformula.com
Old Oct 1, 2001 | 05:19 PM
AZ88Maro's Avatar
used a screw driver to push it back. its good for now. thanks alot
GTAman
Mar 15, 2019 11:40 AM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
tecustomz
Aug 16, 2015 02:28 PM
BrianI
Aug 9, 2015 11:52 AM
