IROC Grill
Car: 91 Formula, 79 Trans Am, 72 LeMans
Engine: 305 TPI, 6.6, 350 Pontiac
Transmission: T5, 3 speed, TH350
IROC Grill
I just am getting around to putting the IROC grill in (the one thats says camaro) anyways, it looks like I may have to drill holes, not too sure, just got a quick look at it.
The grill needs painted however, what is the best way to paint it because I need to repaint the camaro lettering white also. Thanks
1989 Camaro RS
1973 Truck 350 engine
Bored .030 over
.030 Keith Black Racing Pistons
305 Circle Track heads
Ported and Polished, 3-Angle Valve Job, Milled, 1.96 valves,
Edelbrock RPM Valve Springs, 1.6 Rocker Arms
Hedmen Headers
3 inch exhaust w/Flowmaster 80 series
Competition Cam 488 lift
Edelbrock RPM intake
Holley 750 Carb
Open element air filter
Holley Electric Fuel Pump and regulator
MSD Distributor
MSD Plug wires
Bosch Platinum Plugs
No Emissions at all
Turbo 350
B&M shift kit
Richmond 3.73 gears
Daily Driver (till Camaro is done)
1972 Pontiac LeMans 2Door
red with tan top
350 V-8
Turbo 350 tranny
Dual Exhaust w/Glasspacks
K&N Air Filter
1989 Camaro RS
Bored .030 over
Hedmen Headers
Holley 750 Carb
MSD Distributor
MSD Plug wires
No Emissions at all
Turbo 350
B&M shift kit
Richmond 3.73 gears
red with tan top
350 V-8
Turbo 350 tranny
K&N Air Filter
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I'm not into glossy crap, so I painted my grill with satin black rustoleum and it's holding up beautifully. I painted the "CAMARO" with silver model paint, and a small detail brush. It came out great. If you look carefully you'll find that the stock CAMARO paint was silver, not white.
I also repainted my TUNED PORT badge on the bumper the same way.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
Custom Thirdgen Subwoofer Enclosures
"I didn't know a bored out Ford could go so slow" -Shenandoah
The IROC Homepage
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I believe the lettering also came in gold.
JamesC
JamesC
Yes it did!!! Mine is gold...as well as all my emblems and wheel accents, and I have tan interior. I've seen 'em like this with blue,white,black and burgandy paint...but mine is the only one I've ever seen with red paint! I'm sure they're out there, but I've never sen one! Anyone have that combo? Oh and I also used rustoleom spray paint, aand I've never needed to do touch up! It also works for the tpi air lid...and airbox housing under the hood!!!
I've got a few pics on the IROC Homepage of maroon with gold trim. It's actually a somewhat common combo. If you mean bright red, I've seen that before too, but not very much.
The IROC Homepage
The IROC Homepage
Car: 91 RS
Engine: 350 H.O.
Hey camrs i sent you an email at stacysguy@hotmail.com i have a question to ask you if you could please awnser it for me, thanks
1991 teal camaro RS rebuilt 96 350 marine motor, comp cam, accel ignition,8mm accel plugs and wires, hedman headers and y-pipe, and rear end with 4.10 gears. Stock 700r4, best 1/4 time 14.6
mustangman65_79
Aug 11, 2015 03:17 PM
