Carpet
Old Oct 2, 2001 | 06:50 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
Carpet
I want to raise the carpet so I can get at a small area of the floor that's rusted through on the driver's side just about eight inches ahead of the front seat in my 83 TA.
So what do I have to remove to lift the carpet in this area. Is it just that plastic strip that runs paralell to the bottom of the door on the inside that holds the carpet down or what?
Thanx
I was going faster than I'd ever gone before but then I fell off.
[This message has been edited by George (edited October 02, 2001).]
Old Oct 2, 2001 | 08:21 PM
92RSB4C's Avatar
I think it's just the kick panel and the sill panel(plastic think right underneath the door)
BOMB BIN LADEN I see dead Afghans in dead Fords on the side of the desert path.
Old Oct 3, 2001 | 06:32 AM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
It may also help to take the seat out. If you can't lift enough of the carpet to get to it, then you may need to remove the rear seat back, the cushion on that side of the car, and the rear panel next to the seat. Then you should be able to flip the carpet towards the center of the car. Just be careful, lots of times the padding sticks to the carpet.
starliner
Feb 9, 2016 08:18 PM
1992Z28!
Nov 19, 2015 07:33 AM
KNIGHTE
Southern California Area
Oct 22, 2015 09:11 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
indygene
Sep 26, 2015 11:21 AM
