Rear hatch alignment issues
Car: 1992 RS Polo Green Coupe 86 IROC
Engine: 305 TBI
Transmission: Automatic
Axle/Gears: Yes it has some!!!
Hey guys, I have an 83 Z and I have tried and tried to realign my tail/hatch back on the car. I have at least 1/2 to 3/4 of an inch of the hatch sticking past the rear quater where the air spoiler wraps around and down. I recently went to a cruise night and met another third gen owenr. His wasn't as bad, but we both have the same question. How the heck do you adjust this. I have pulled the hydro pistons and loosened all four bolts on my hatch trying to rack it around to get proper alignment. Nothing has helped. I went as far as pulling the rear plastic from under the tail to see how it's held on there. I'm afraid to get too pushy with it cause I don't want to break my window. Has anyone tried this? Are there any pictures on a how to????? Thanks Matt
Car: 1987 IROC Z w/T-Tops
Axle/Gears: G92
Re: Rear hatch alignment issues
Welcome to the site. Fill out your profile details and take advantage of the search box. You can also click on the search pull down menu, choose advanced and then search using keywords. Here's one link for now and you can find others using my directions above. Good luck!
Start at post #22:
https://www.thirdgen.org/forums/inte...info-rear.html
Start at post #22:
