Where do I get discontinued ground effects retainers??
Old Oct 12, 2001 | 03:27 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
As usual, nothing's easy. My parts came in for my GTA, and one of them is the wrong part. Turns out the right part is discontinued.
Anyway, these are basically impossible to find used because they usually break when you take the ground effect off, and none of the junk yards in my area have ever even heard of a "Trans Am". Anyway, it's the retainer that slides into the passenger side rocker panel ground effect with the 2 studs on it. The studs go through the fender and are held on with nuts from the back side. The GM part number is 1005128. My local dealer called all of the dealers that showed that part, but none had it. Where do I go next?
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
Custom Thirdgen Subwoofer Enclosures
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Oct 13, 2001 | 06:03 PM
Earl 87gta's Avatar
I know this is going to sound weird but it works go to a RV dealer any place that sells campers or motor homes and what you want is to buy a toilet bolt kit thats right the bolts that hold the toilet to the floor they are ¼ with a flat head on them you can use them like they are or for support use a piece of aluminum sheet metal. I know it sound crazy but it works that’s what I used.
Old Oct 13, 2001 | 06:42 PM
Bawls's Avatar
Car: 1985 IROC-Z
Engine: LB9
Wow, now thats a good tip if I ever heard one.
No License, No Hope.
http://z28.crushed.org
Hotrodboba400
Dec 10, 2019 07:07 PM
codeysabatini
Exterior Parts for Sale
Sep 24, 2015 05:40 PM
billybob6110
Sep 23, 2015 01:30 PM
ASE doc
Sep 22, 2015 03:13 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
