Need help.
Old Sep 7, 2013 | 03:56 PM
jkbmelroy's Avatar
Car: 92 chevy truck
Transmission: auto
Need help.
I'm a third gen lover there is no other way to put it ive recently found a 84 camaro and was wondering are all third gen bodys the same, meaning can i swap out the better looking front clip, side skirts, and rear bumper of a 92 onto the 84?
Old Sep 7, 2013 | 11:16 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Re: Need help.
Parts are interchangeable but you may need to swap the front fenders as well. Not sure the 84 fender lines will match up to the 92 nose. 85 and up are fully interchangeable.
Old Sep 7, 2013 | 11:36 PM
toyotekk's Avatar
Car: 91 camaro rs
Engine: 5.0l
Re: Need help.
You can swap all the skirts but you may need to drill 2 holes in the lower part of the fenders and the rear quarters
Old Sep 8, 2013 | 08:51 AM
cdoyle's Avatar
Re: Need help.
84 here!
Yes you can swap out the front bumper and add the GFX. You will need to cut a couple slits on the fenders for the front skirt. No biggie though.
Old Sep 8, 2013 | 11:39 PM
jkbmelroy's Avatar
Car: 92 chevy truck
Transmission: auto
Re: Need help.
perfect thank you all for your time i appreciate it.
Old Sep 11, 2013 | 02:36 PM
camaroracer21's Avatar
Car: 1983 Camaro
Engine: 358 SBC
Transmission: TH350
Axle/Gears: 9" Ford 4.56s
Re: Need help.
I swapped front bumpers on my 3rd gen. Had to drill the holes out a little larger to make it fit perfectly. Took a decent amount of time and effort to make sure both fenders had the same gap with my fiberglass hood. Started out at almost an inch gap on the passengers side. was able to get it closed up to virtually no gap. With a little tender love and some patience, front bumpers and fenders are able to be swapped
Elephantismo
Feb 13, 2019 12:51 AM
Quzyle
Oct 15, 2015 03:35 PM
Numbah-1
Oct 2, 2015 08:27 AM
Jonas Earl
Sep 27, 2015 07:39 AM
Racerx974
Sep 19, 2015 10:16 AM
