Door rattle fix/needs improvement
Car: 1990 camaro rs
Engine: 5.0L 305 tbi
So every time i hit a bump my entire door would jump, with the door open i lifted up on it and there was no play in the hinges or pins. So i figured it was the striker. I did a trick i learned on here, took the plastic cover off the striker for the rear seat latch. I cut it to length then cut a slit down the side so i could open it to put it over the door striker. It works, amazingly well at that. But the plastic is already cracking, so there must be a better solution. Has anyone else tried this or know a better way? If i take off the door striker and slide the plastic over it rather than cutting a slit on it would that keep it from cracking more?
Car: 1990 camaro rs
Re: Door rattle fix/needs improvement
Sorry, after reading JamesC's sticky i guess i'll try it his way and slide it over and see how it works.
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
Man i had a problem with mine but that wasnt my problem it was all the window channels inside the door I worked all weekend fixing them they sound like a new car door now
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
and if you lift up on the door with it almost shut, you'll probably find your play in the hinges
Engine: 4++,350 & 305 CIs
Weld in subframe connectors will help that also.
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
My doors are pretty darn good, but since fixing them in 2010 (or whenever I did it) they have since loosened over time.. I believe it to be a few things:
1) Rivets aren't perfectly tight on power door lock and window motors.. some people here use nuts and bolts, going to try that to get them tight.
2) The plastic door panel top panel (the black panel that runs along the top of the door panel) seems to always come loose from the door panel itself.. I have used glue but now I am going to use epoxy and really solidly mate that bugger together.
3) I could use automotive tape to reduce the rattling of the rods.
4) My window vibrates at certain heights, this is probably due to the roller bushing on the window track which I actually purchased from TDS (atleast I think this is the part for that lol). That would definitely help reduce rattling.
5) Putting Hushmat / Dynamatt inside the door frame will make the door sound much much tighter when closing and when driving.
Car: 1990 camaro rs
Well when i had the plastic piece on there it worked great, no movement at all. But since i had the plastic piece slit it didnt last long so im gonna redo it the right way. The hinges actually dont have any play in em.
Car: 85 Silver Iroc, 79 Camaro
Engine: LB9, 500+ ci BBC
Transmission: 700R4, th400 with brake
Axle/Gears: 3.42, hand made 40 spline 9"
I think wire hole grommets would work on the rods to prevent noise, just slide them on a viola!
IROCZDAVE (88-L98)
Sep 17, 2015 07:43 AM
