how to take care of rust pits?
Car: 1984 Z28
Engine: Vortec 350, hotcam
I'm going to start grinding off some rust in the next few days and i'm wondering what to do with any rust pits if I find any. Body filler? is there a primer that will cover it in a few coats? That's the next question, what primer should I put on bare metal to seal it again? It only has to last till spring because hopefully then I can get the car painted. Also what type of disk for the grinder. I have one now that looks like a sponge that's cut in half or should I get the wire wheel type? Any input is appreciated
Re: how to take care of rust pits?
Personally I like to use a 36 grit disk on a mini angle grinder and then a sandblaster to get the rust out of the pits. I know some guys use the wire wheel, that can help too. If you have pits then you really need to use the sandblaster. If you don't get every speck of rust out it will come back. If you fill over pits that still have rust in them then the rust will grow and pop out the body filler later on. There are products that 'freeze' the rust that can be painted over... I can't speak for how well they work but I suppose thats an option of you don't own a air compressor for a sandblaster. You can use a little body filler or glaze to smooth out the area after you've sandblasted before you prime. I don't recommend and primer out of a can, its all garbage in my opinion. The best option for priming is a light coat of self etch primer and then 3 coats or so of 2k primer, though you could skip the self etch if you wanted to.
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
if it is not a top panel then I would sandblast it out or if it is a top panel you need to use SEM rustmort apply and wait 48 hours then sand with 320 grit sandpaper then apply epoxy primer it is water proof and will hold up for years if needed you can try to sand or grind them out but if you leave any rust in the pitts it will come back to bite you
Car: 91 canaro rs
Engine: 5.0
Transmission: 5 speed
Engine: LQ4 ls 6.0
Yeah I have been told that and they said if I was concerned let it dry for 48 hours not 24 I have been using it for 20 years never had a problem and I also wash it down with water before I prime
Linson
Oct 1, 2015 09:50 PM
