87 gauge layout to a 90 or so????
Car: 1991 Formula
Engine: 6.2 383 TPIS Miniram
Axle/Gears: Moser 9" 4.11
Is it possible to change from the stock 87 camaro gauge layout to the newer sleeker ones located in the hmm Id say early 90s camaros??? They look more like the gauges blend together then sit separate.
1987 Chevrolet Camaro
2.8 Ltr HO Cut air boxes K&N Filters Gutted Cat (Did I say gutted opps don't tell the officer)
Duel catback Exhaust With Flowmaster series 80 dual 5"X24" MONSTER Echos
97 Firebird 16X8" Rims
you have to change the whole dash that way
84z28HO
355
open element/k&n
m5/hurst billet plus shifter
83 z28 fiberglass hood
10bolt w/3:42posi
gm aluminum driveshaft
performer intake
performer 600cfm carb
accel 8mm wires
adjustable thermostat switch
160 stat
gta rims
gts blackouts
s.s rear control arms
s.s panhard rod
s.s subframe connectors
98 camaro rear springs,shocks
98 z28 leather seats
95 camaro rear view mirror
"wonderbar"
4th gen z28 tips
http://www.geocities.com/toosloz/84camaroz28.html
84z28HO
355
open element/k&n
10bolt w/3:42posi
performer intake
accel 8mm wires
160 stat
gta rims
gts blackouts
s.s panhard rod
"wonderbar"
4th gen z28 tips
Car: 1991 Formula
Whole dash (pad and all) or just the cluster set???
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I think because the panels are all different, from the knee pads, up, you have to replace everything. Take me about 6 hours or less to do the swap...Of course I have done it beofore.
on firebirds though.
I could tell you how to do it on a firebird by memory, buuuttt, you have a camaro.
John
John
