Drip Rail Molding Removal
Old Oct 2, 2013 | 12:22 PM
Cars'n'Guitars's Avatar
Car: 1985 Camaro Iroc-Z
Engine: Currently Deciding
Transmission: TH350 Built
Axle/Gears: 3.73 POSI
Okay so how does the drip rails come off on these cars without damaging them?
Attached Thumbnails Drip Rail Molding Removal-picture-012.jpg   Drip Rail Molding Removal-picture-013.jpg   Drip Rail Molding Removal-picture-014.jpg
Old Oct 2, 2013 | 12:35 PM
'86 Sport Coupe's Avatar
Car: 1986 Camaro Sport Coupe (Part Out)
Engine: 2.8 MPFI V6
Transmission: 700R4 Automatic 4 speed
Axle/Gears: 3.42 Open With Drum Brakes
Re: Drip Rail Molding Removal
I think you have to pull the weather striping off to get to the bolts that hold it on. that is what I did when I pulled them off a '91 RS. If anybody knows of a way to pull them off without removing the weather striping then let us know!
Old Oct 2, 2013 | 01:05 PM
That's what I thought, thanks for the help.
Old Oct 2, 2013 | 01:30 PM
Engine: 2.8 MPFI V6
[QUOTE=Cars'n'Guitars;5645449]That's what I thought, thanks for the help.[/QUOTE
Your welcome. Just be careful pulling the weatherstripping out it could break if you pull to fast. Something to consider if you are trying to save yours.
Old Oct 2, 2013 | 06:39 PM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
There isn't a way to take them off without the weatherstripping coming off. Gently remove that- that gives you access to the screws that hold the strip rail over the drip rail. Remove those and the drip rail should just pull out. Reinstall screws and weatherstripping. And glue the weatherstripping in! Mine isn't because I am going to strip it back for paint, and I have to be careful when washing the car as the water can blow right under the weatherstripping and into the interior, particularly if you get lazy and run it through a car wash the first time- ASK ME HOW I KNOW!!
Old Oct 2, 2013 | 10:44 PM
Thanks guys, and no I don't plan on saving it the weatherstripping needs replaced and I doubt I will since it is going to be a drag car.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
92projectcamaro
Jan 18, 2016 08:00 AM
TheExaminer
Sep 6, 2015 11:40 PM
Strick1
Sep 4, 2015 07:11 AM
RyanJB
Sep 2, 2015 01:27 PM
