T-Top wind noise
Old Oct 24, 2001 | 07:26 PM
92blackbird's Avatar
Car: 1992 pontiac firebird
Engine: 305 tbi
T-Top wind noise
I know this has probably been asked before, but I get a LOT of wind noise at the front of the driver side t-top. Surprisingly, I have no tears in the weather stripping, and no water leaks at all. Just that damn wind noise. Starts about 50mph and gets worse the faster I go. Any suggestions to quiet it down some? Also the tops are in real good shape.
'92 firebird t-tops
305tbi,670cfm tbi, 2 1/2" Dynomax catback, 9x3 K&N open element
Old Oct 24, 2001 | 08:25 PM
Brent Swan's Avatar
Could try slightly lowering that particular corner of your T-top.I had the same prob,that fixed her right up.
Brent
Old Oct 25, 2001 | 08:49 PM
One Eyed Jack's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Brent Swan:
Brent
</font>
What?
FOR SALE - email me
Old Oct 25, 2001 | 09:21 PM
KlayBuRn's Avatar
the place where the t-tops lock in at, you can take off the trim, and adjust that, that fixed mine also...
Old Oct 27, 2001 | 08:06 AM
Engine: 305 tbi
Thanks a lot! I didn't know the tops wre adjustable. Sounds like the right answer.
Old Oct 27, 2001 | 08:32 AM
Brent Swan's Avatar
To 92blackbird..Yeah like the above post,just remove your T-top.The location where your T-tops latch at,remove either side of trim by removing the small black screw..slightly pull down on the trim to gain access to a small bolt,loosen the bolt,you should then be able to slide up or down the small mounting plate,the slighest movement will lower or raise your T-tops,but i kept on having the problem of the mounting plate sliding back into the position that it was in orginally in..so all i did was hold the plate with one hand very tightly and slowly tightened the bolt to spec..secure your trim pieces back,install your T-tops back into your car.Crank her up,take off onto the road and find a Mustang to smoke and hopefully the only wind noise you wil hear will be the noise of you passsing his behind!!....hehehe..:8^)
Brent
Toys currently owned:
-91 MPFI Firebird
-97 Grand-Am GT
-96 Extreme Sonoma
-91 Suzuki GTS500E
Old Oct 28, 2001 | 08:52 AM
Engine: 305 tbi
Great help guys. Going to do that this a.m..
I'll let you know the results.
Old Oct 28, 2001 | 09:07 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
Hey One Eyed Jack
Nice looking car in the pic. I take it that is you on the right
Old Oct 31, 2001 | 03:42 PM
Engine: 305 tbi
Thanks for the help!!! It worked great. No more t-top noise. Now it's just on th eside windows.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
