Headliner woes
Headliner woes
Lads,
The headliner on my bud's '83 RS peeled off, drooped, sagged & otherwise failed, to the point where push pins weren't gettin' it anymore, so we removed it. He's now drivin' around in a Camaro-shaped echo chamber (Now batting for Pedro Guerrero.... Manny MOTA...Mota...mota.....), so we need a new one. Who makes 'em? Dealer-only item? Man, I sure hope not.
Cardboard, foam & cloth, huh? What the HECK was Chevy thinkin'? Hard to say which is sleazier, the headliner or the rear shock mounts. LOL
As always, cheap is good.
Thanks,
Scott
Thanks,
Scott
I got mine at thirdgenparts.com for $10. I do live 5min away and picked it up, but you should be able to find one at a junkyard. At the worst you may have to recover it. If you get one that need recover they'll give it to you for nothing.
Car: 85 Trans Am WS6
Engine: 305HO L69
how is the headliner board on the liner you pulled down? if it's not too bad, you can throw on a few thin layers of fiberglass and recover it to brand new condition for like $30 i think
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
When I did my headliner, I took a fine wire brush to the surface to get all the old glue & old foam off. Used headliner adhesive spray for the glue, worked like a champ. ALOT cheeper than getting a new one. Try to get used if you can.
John
John
formula00ra
Interior Parts Wanted
Sep 28, 2015 11:50 AM
