Core Tag Rivets
Car: '89 GTA
Engine: ZZ6TPI
Core Tag Rivets
Does anyone know if the rivets for the core support tag are available anywhere?
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Core Tag Rivets
Try this place,they handle GM Specialty rivets
http://www.clipsandfasteners.com/Spe...a_p/a12656.htm
Engine: LS1, LB9, L03
Re: Core Tag Rivets
Careful with what you use to replace it...if it's not 100% exactly the same rivet, people will likely suspect that the car's been tampered with.
