Got a leak
Old Oct 23, 2013 | 01:43 PM
LastGTA's Avatar
Car: 92 GTA
Transmission: A-4
Got a leak
So my car has been smelling a bit musty for a while and I thought it was the T-top or hatch seals. I finally did some testing and searching and here's what I found. Took the car through a car wash and not 1 drop from the tops. Tested the seals around the tops, windows and hatch with a piece of paper and they all seem good. The car has been sitting outside lately and after a long rain I noticed there was water puddled up where the drivers side rear seat bottom should be (rear seats are out at the moment). Seems like there was a wet trail on the carpet from the door to the well. Could this be my door seal?? Car is a 1992 BTW. Also what's the best way to get the musty smell out of the car?? Thanks
Old Oct 24, 2013 | 02:49 PM
punkmaster98's Avatar
Car: 1984 T/A
Engine: LQ4
Re: Got a leak
have you tried sitting in the car will having someone spray it with water?
Old Oct 24, 2013 | 05:37 PM
James Sutton's Avatar
Car: 1991 Camaro RS yellow
Engine: was '91 V6, now '89 5.7/355 TPI
Transmission: 4 speed automatic
Axle/Gears: Moser 3.73 with zexel posi
Re: Got a leak
Did you look UNDER the seat? You could have a hole in the floor.
Old Oct 25, 2013 | 11:35 AM
LastGTA's Avatar
Car: 92 GTA
Transmission: A-4
Re: Got a leak
I was in the car through out the car wash and nothing came in so I don't think having someone hold a hose would do it. Seems that it happens with it rains all day.
No holes in the floor. I was under there inspecting the under carriage when I pulled the motor and trans for my LS swap. Car is solid.
Has anyone heard of the door seals leaking? Where the door and body meet under the window.
Old Mar 15, 2015 | 03:40 PM
blackfrontier's Avatar
Car: 89 GTA & 76 T/A
Engine: 5.7/455
Transmission: GTA Auto/76 T/A 4speed
Re: Got a leak
My 89 GTA also has a weird leak like that. The drivers side rear seat get a drip from the rear plastic ceiling panel. I have removed it and seen water drip out the hole the screw goes in to hold the panel up too. Not sure how water is getting in and t-top seals in the center near the t-bar are tight. Any suggestions would be fantastic!
RS Reaper
Oct 17, 2018 07:52 PM
Mark_ZZ3
May 24, 2018 01:02 PM
Reid Fleming
Oct 10, 2015 09:56 PM
aaron7
Sep 30, 2015 09:15 AM
mfp189
Sep 27, 2015 09:25 AM
