Iroc trunk spoiler only - no flares
Old Oct 23, 2013 | 06:44 PM
Asim's Avatar
Hey guys
I've taken a 92 and swapped the deck lid, but have not added the side flares, and since its a 92, the fenders don't have the holes.
I'm debating adding the flares. The 'lip' look, is growing on me.
What do you think?
Best,
Attached Thumbnails Iroc trunk spoiler only - no flares-iroc-003-640x480-.jpg   Iroc trunk spoiler only - no flares-iroc-007-640x480-.jpg
Old Oct 23, 2013 | 08:22 PM
jharrison5's Avatar
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
Re: Iroc trunk spoiler only - no flares
It's definitely a unique look. Your Camaro looks to be in pretty good shape so I don't think you really should cut holes into the rear quarters. It's your car though so do what you feel is necessary.
Old Oct 23, 2013 | 08:43 PM
RockJay81's Avatar
Car: 84 Z28......99 TA
Engine: Lq9 6.0... Ls1
Transmission: 4L60E X's 2
Axle/Gears: 3.73 on both
See if you can make the sides one piece and not let it touch the side 1/4 panel. I always wondered if it could be done
Old Oct 23, 2013 | 09:06 PM
Buggy Disaster's Avatar
Car: 91' Z28. 70' Dune Buggy
Engine: LSX Cam/Full Bolt ons
Axle/Gears: 4.10
I've wondered the same RockJay. I have always wanted a hawks 5" spoiler, but refuse to drill holes in my quarter.
Old Oct 23, 2013 | 10:37 PM
IROCgiraffe's Avatar
Car: '87 IROC-Z | '99 SS
Engine: LB9 | LS1
Transmission: 700R4 | T56
Why don't you try using double sided adhesive and remove the bolts so you don't drill any holes?
Old Oct 23, 2013 | 10:44 PM
Asim's Avatar
I thought about the double sided tape. I guess I'm worried that if the General used 3 bolts, the air catching them probably means they come under some load.
I'm first trying to decide if I even want to put them on. I kinda like the way it looks now, which is why I posted.
Old Oct 29, 2013 | 09:09 PM
anobii's Avatar
Car: 86 Camaro SC
Engine: 5.3L LM7
Transmission: TH350
It looks ok, but it looks incomplete. I'm undecided whether I like it or not lol!
If it were mine I would probably mount the corners with the sticky tape, if for nothing else so people wouldn't think I was an underachiever lmao! I definitely wouldn't drill the holes though.
If you do mount them with tape, Lowes carries Scotch/3M brand Extreme mounting tape. It's outdoor rated and 1 sq. in, will hold 20lbs. It's impressive how strong it is.
Old Oct 30, 2013 | 11:41 AM
Ruckusz28's Avatar
Car: 1986 IROC-Z
Axle/Gears: 4:10
It looks different, but not in a bad way. If you like it, keep it!
Frozer!!!
Jan 19, 2024 04:55 PM
colton_carlson
Mar 8, 2019 12:21 PM
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
AmorgetRS
Convertibles
Aug 31, 2015 11:55 AM
mustangman65_79
Aug 11, 2015 03:17 PM
