rust and por15 question
Old Nov 16, 2001 | 03:25 AM
Diabolical's Avatar
Car: 85 Trans Am WS6
Engine: 305HO L69
my car has a bunch of small rust bubbles on the body panels, a rust spot about 3"x3" on the rear quarter panel, and a 2"x2" hole rusted through into the spare tire compartment. most of this will be hidden by the gfx that i'm putting on, but i still want to fix them. what's the best way to sand/grind the rust spots down? for the hole, what's the easiest way to fill it in(welding in new sheet metal is not an option). i'm going to put some por 15 on the rust spots before i get the car repainted. which por 15 formula should i get, black, silver, or clear? will a pint be enough?
Old Nov 16, 2001 | 10:48 AM
Flash84Z28's Avatar
Car: '03 S-10/ '87 Trans Am
Engine: mild 350
Transmission: TH350
I posted about a week ago with a similar problem. The answer I got was to use the POR 15 floorboard repair kit. It cost $120. I'm going to coat the rest of my underbody with it too, to prevent any more damage. I have the same rusthole in the same places you do. The website is http://www.por15.com Not sure if you knew it or not.
1984 Camaro Z28 - Black w/ Grey int.
-GM Goodwrench 350 with Edelbrock 600 Carb, Edelbrock Preformer RPM intake, AC Delco plugs, 8mm AC Delco wires, 14" Accel filter, Homemade Cold Air Indctn., Edelbrock Chrome valve covers, breather, and Air cleaner.
- Profesionally Built Turbo-350 with 2500 RPM Stall converter, Hurst shifter, & one wicked shift kit.
- Eagle Alloys 15" Alum. Rims surrounded by P235/60R15 BF Goodrich Radial T/A's
-Comming Soon:
3.73's, MAC Cat-Back, hollowed cat., B&M Megashifter, & Paint: Navy Blue Metallic w/ Silver strips
Pics at: http://members.fbody.com/flashz28/
Frozer!!!
Jan 19, 2024 04:55 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
69 Six Pack
Oct 5, 2015 07:51 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
redmaroz
Aug 16, 2015 11:40 PM
