GTA door panel swap...all feedback welcome
Old Nov 15, 2001 | 10:45 PM
Brent Swan's Avatar
Alrighty just as the subject line states,i need some of yalls feedback on what modifications if any has to be done in order to correctly install GTA door panels onto my base Firebird.I can pretty much take the door panels off,but how the heck do you remove the trim around the handle and power door locks?and will all the pieces change over to the GTA ones?Back to the modifying question,do i have to do anything to the inner guts of the doors in order to mount the arm rests?Any advice and tips on this subject would sure be greatly appreciated Thanx in advance to all that reply.
Brent
Toys currently owned:
-91 MPFI Firebird
-97 Grand-Am GT
-96 Extreme Sonoma
-91 Suzuki GS500E
-89 Z28 Camaro(under construction)
-89 RS Camaro
Old Nov 15, 2001 | 11:29 PM
Tonyrodz's Avatar
Transmission: auto
Well--I put those panels in my T/A--you need to drill some new holes into the metal plates on the doors(riveted to the door)--right behind the old armrests--as for the plates where the locks go--in the center there's a small plug that's hiding a screw-take the screw out--remove it(plug) w/a very thin screw driver--and the plastic piece that covers the lock slide should pull right out--very simple swap to do--and worth it!!
Hope I explained it right! Hardest thing about this swap is pulling the panels off w/o breaking the plastic tabs behind it!
[This message has been edited by Tonyrodz (edited November 15, 2001).]
Old Nov 16, 2001 | 03:36 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Just a note: the base firebird had the option of those door panels, they came with the "deluxe" interior which also had seat-pockes.
You will need:
-the door panels,
-the inside door handle (there is a screw that attaches the panel to the door) the location is different than the base interior.
-& the afore mentioned bracket.
John
G O D BLESS AMERICA
http://www.3rdgenformula.com
87 Formula 5.1 TPI Auto Modified (Yellow/Black)
87 Formula TPI (5 Speed) Yellow/Gray STOCK
14.8sec 1967 Buick Riviera
1990 Buick Riviera (driver)
83 Camaro
83 T/A
1992 Trans Am
May 10, 2023 07:19 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
IROCZDAVE (88-L98)
Sep 13, 2015 09:07 PM
kkirch15
Interior Parts Wanted
Aug 28, 2015 10:03 AM
Out-Cast
Aug 23, 2015 06:33 AM
