Question on T-5 shifter.......
Old Nov 16, 2001 | 04:16 PM
elevario's Avatar
Car: 1992 RS
Engine: 3.1L V6
I looked at a z-28 with a five speed the other day and the leather boot was wrapped right underneath the black **** shifter. It looked really weird but kind of cool. Is this how it's supposed to be? Because on my shifter, the leather is at the bottom of the shaft. If it is supposed to be that way like on the z-28, how can I fix mine to stay at the top? Oh yeah, has anyone cut their shaft so it doesn't stick up as high? Sorry for all the questions, I really appreciate it!
1992 Polo Green RS 3.1L K&N conical and working on the ram air....
"Yeah, it's a V6 SO WHAT!?"
Old Nov 16, 2001 | 08:20 PM
johnsjj2's Avatar
Car: 1991 Z-28
Transmission: T-5 (gonna buy the farm)
Mine was at the bottom of my shift **** too. (He said ****!!) Anyway, I thought it might have an aftermarket shifter, but upon further investigation, I found it was stock. I did cut about 2" out of the middle, and then welded the threaded part back on. If you do this make sure you have enough room in each gear so you don't smash your fingers. I didn't do this and the first time I hit reverse, I nailed my finger between the ball and the lower, right corner of the hole in the console. You would not believe the force you use to shift, until you have a brain fart and do what I did. As far as shifting difference, it is minimal. Its by far equivelent to a short throw shifter, but a little better.
Joshua Johnston
1991 Z-28
350, T-5, K&N, Ported Vortec heads, Edelbrock RPM, Holley 750 D.P., HEI, 11.07:1 CR, Comp Cams Roller-.510"/.520"-282*/288* dur., Shorty Headers, Dual 2.5 Exhaust, Dynomax Bullet Mufflers, T&R Motorsports custom air intake, Bald tires
Old Nov 17, 2001 | 03:09 AM
elevario's Avatar
Car: 1992 RS
Engine: 3.1L V6
Cool, thanks a lot man!
Old Nov 17, 2001 | 04:45 PM
crucial's Avatar
I cut mine to fit too. I got an aftermarket **** that didnt have the threads but instead it clinged on with three allen screws. I cut the threaded part off plus about an inch. Now it sits nice and low and looks perfect.
1992 Z28 5.7 TPI
ZZ4 longblock
Harland Sharp roller rockers
Accel base and SLP siamesed runners,
52MM SLP Throttle Body
Hooker Headers & Flowmaster catback
MSD6A ignition
aluminum driveshaft
World Class 5-speed
Old Nov 18, 2001 | 07:46 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The stock shifter should have a small metal ring affixed to the upper portion of the shaft, a couple of inches or so below the threaded section. A rubber piece slips over the shaft and settles on the ring--it's this piece that keeps the boot in the correct position, just beneath the ****/ball. By the way, should you be missing this rubber piece, remove the shifter plate and check around inside the console. That's where I found mine. FYI, my B&M Ripper also has accommodation for the rubber piece.
JamesC
Old Nov 19, 2001 | 05:35 PM
elevario's Avatar
Car: 1992 RS
Engine: 3.1L V6
Thanks a lot man! I will try and look at the bottom of the shifter for it. Thanks for the advice!
Old Nov 19, 2001 | 07:23 PM
Hulk0202's Avatar
I cut mine and used epoxy to put it back on. Now how2 do I get it off to put my new shifter in............?
Old Nov 20, 2001 | 12:35 AM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
I put a WC-T5 in my 82 T/A, and noticed that the shifter is really low as it is. The shifter is untouched and stock. In second, fourth, or reverse, the ball almost hits the cover plate. I think that if I shortened it, then the ball would be below the cover plate. Anybody have any problems like that?
Old Nov 20, 2001 | 06:40 AM
JamesC's Avatar
I was surprised at the heighth difference that swapping in a poly tranny mount made, so perhaps part of the problem is a ten or fifteen-year-old rubber mount.
JamesC
midge54
Sep 2, 2015 06:27 PM
transamgta87
Sep 1, 2015 07:07 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
Cacike
Aug 27, 2015 05:10 PM
redmaroz
Aug 16, 2015 11:40 PM
