Can you explain what these are? 90-92 high rise
Old Nov 22, 2013 | 09:37 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
About to buy this off a friend, I would like to know what these holes are for exactly, I remember reading that 6 holes are required I'm counting 2 per post, and one on each end totalling 6 studs, so what are these for? These are the ends of the spoiler what are the square holes for?
Old Nov 22, 2013 | 11:29 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Re: Can you explain what these are? 90-92 high rise
Old Nov 22, 2013 | 11:17 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
There use to be 2 little metal tabs on there.. There would be 1 screw on each side that went through the deck lid and into the metal square clips that slid over the edge of the spoiler in the square holes..they were similar to the clips that the fender attaches to.
Old Nov 22, 2013 | 11:27 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
So are they necessary?
Old Nov 23, 2013 | 12:24 PM
Not really,it will still mount and bolt down just fine...if you pull up hard on the wing after it's bolted down the front will lift a little but nothing major..I would put some sealer or a small piece of windshield ribbon around your bolt holes and tighten it down..snug it down real good but don't try cranking down on the bolts too hard because you could break the studs off of it..should be good to go.
Old Nov 23, 2013 | 02:12 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Um, no, no, and no.
Those holes are for the GASKETS. The gaskets have a hook that goes up and pushes forward to lock them to the end of the spoiler. Then the rear of the gasket goes over the stud. There is only one hole in the gasket for the stud and the rest is solid and smooth.
There is no clip and there is no bolt there. If there is on your car, then someone did something screwy in the past and lost some parts. If it were factory and you could prove it, then I'd believe you.
Old Nov 23, 2013 | 06:50 PM
well,Idk..heres a pic of mine..was done a couple years ago..I removed the hatch and spoiler when I painted it and I don't believe the wing had ever been off before because when I took it off the very brittle gaskets crumbled..and also notice,there are a total of 8 holes in the deck lid..There were 2 very rusty clips on the front in that square opening..that much I am very sure of..
https://www.thirdgen.org/forums/atta...91-z28-013.jpg
full thread can be seen here.https://www.thirdgen.org/forums/body...onna-save.html
Old Nov 23, 2013 | 07:00 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Ok so they're for the gaskets that are unobtainable at this point??
I only plan to drill the 6 holes but I still need a solution for the gasket
Old Nov 23, 2013 | 07:05 PM
I used this on mine..
http://solutions.3m.com/wps/portal/3...glT4X59JN54Tbl
Pac J
May 17, 2020 10:44 AM
sp8ty
South East Region
Sep 24, 2018 03:55 PM
sp8ty
Exterior Parts Wanted
Oct 23, 2015 08:35 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
