ram air hood not sitting flush?how to fix it?
Car: 1986 camaro iroc z
Axle/Gears: stock
ok so i got a functioning ram air hood for like 60 bucks at lkq from a 91. and it oesnt sit flush with the front bumper i dont know how to it sits flush fine with the funders but not the front bumper. and it takes me slaming the hood to actualy latch it . can someone help me please?
Car: 1985 Z28 & 1997 Z28 SS SLP
Engine: Sbc 305 TPI & LT1
Transmission: 700r4 and A4
Axle/Gears: 9 bolt Posi 323 & Posi 323
Re: ram air hood not sitting flush?how to fix it?
Try Adjusting The Rubber Bumper Stops. 1 One Each Side......Good luck
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
dude,why start a new thread? What was wrong with one you started on the 8th?
https://www.thirdgen.org/forums/body...t-linning.html
you need to check your bumper stops at the front and rear as mentioned already..and I also looked at your pics,looks to me like your bumper cover is a little tweaked on the driver side..like someone sat on it or something..if so,your alignment issue definitely lies there.
try taking the front ones out completely..see where it sits then..also,did you ever adjust the latch on the body down a little?
Axle/Gears: stock
well see how the owner use to hit the old hood to open it cuz of some reason i need to straighten it i was told to shim it up to line it up but wasnt told exactly were to put them
If it is a cheap fiberglass hood you may have to live with it. They are known for fitting like garbage.
Street Lethal
Apr 30, 2019 12:14 PM
