Removing paint from shaded T Tops
Old Nov 29, 2013 | 06:09 PM
2firebirdpals's Avatar
My 84 has painted T-Tops the color of the car- BUT- there are some peeling areas ...... I want to strip off the enamel from the T Tops BUT not harm the T Tops mirrored surface--- what is the safest way of removing the painted surface . thanks
Old Nov 30, 2013 | 09:27 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Re: Removing paint from shaded T Tops
I think the mirror is on the inside, so you should be ok using acetone, stripper, etc, just make sure it doesn't touch the trim or drip to the underside where the mirror is.
Don't use any metal scrapers or you will scratch the glass.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
I'llrocya
Exterior Parts for Sale
Nov 11, 2015 05:45 PM
3rdgenparts
Aug 8, 2015 07:09 PM
