hood blisters on a flat hood
Old Nov 22, 2001 | 12:13 PM
92RSGUY's Avatar
Is it possible to put the hood blisters on a flat hood, or do you need one that already has the louvers so that you know where to place them?
Old Nov 22, 2001 | 12:18 PM
Drew's Avatar
The hoods with blisters are the same hoods as IROC hoods. Without the indents they mount in, it looks trashy.
Old Nov 23, 2001 | 12:04 AM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
there was actually a post about this a little while ago. someone found a place online that sells hood blisters that can be mounted on any (including our flat f-body) hood.i can look for the page when i get back home on sunday
Old Nov 23, 2001 | 03:41 AM
Diabolical's Avatar
Car: 85 Trans Am WS6
Engine: 305HO L69
there was a post about it, but the ones someone posted that would fit the flat hoods, they looked like really cheap immitations.
87 Camaro LT
bone stock 305 w/ 700r4 0-60: 3 minutes
mods to come:
ground effects
93 camaro seats
99 camaro center console
91 z28 rims
white 145mph iroc gauges
Old Nov 23, 2001 | 10:09 AM
91Zman's Avatar
Car: 1991 Z28
Transmission: 4L60 automatic
They were cheap imitations made for trucks.They are a lot shorter and not as wide as the stock ones.
1991 Z/28 350TPI
1973 Camaro Z28(project)
member of the GULFSOUTH FIREBIRD/CAMARO CLUB (NEW ORLEANS)
Old Nov 23, 2001 | 06:54 PM
arthur's Avatar
While I was trying to piece together a '91 Z28 styling, I came across some loose hood blisters. The guy wanted $125 for both, and they were in good shape. The reason I bought them was because it looked loke they bolted onto the bare RS style hood, because edges tappered into the base. I imagined it would only require aligninging them with measurements from an original blister hood, them marking the holes to drill. I had plans to do this to a stock fiberglass '83 hood, which would require a little rework anyway. Then I bought a '91... 'cause the parts were too expensive in pieces.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
PurelyPMD
May 5, 2016 04:57 PM
mr z28
Exterior Parts for Sale
Dec 14, 2015 05:14 PM
IROCTheHouse
Oct 26, 2015 02:35 PM
skinny z
Oct 5, 2015 06:23 PM
