Overhead console questions
Car: 1986 Monte SS / 1988 Iroc-Z
Engine: LS3 / L98
Transmission: 4l80E / T56
Axle/Gears: 3.73 / 3.45
Hey guys, posting for a friend again about an over head console in a 83 (I believe) berlinetta. it has the console with the movable light, leather pouch, and all the other "goodies" up there. now my question is, how hard is it to take it out and put it into a 91 camaro. what wires are necesarry to hook it up and are there holes already in there that the originals would screw into?
So, basically We can get it for 25 dollars, and it is in really good shape. Basically want to know how to get it out and install it and have everything working.
Thanks again
Nate.
1994 Camaro Z28. PURE BLACK. Hardtop automatic.
Pics of the Z
1989 Camaro RS. Bright Red/ 58,XXX miles. SOLD
1983 Camaro Sport coupe rusted out blue with green spray paint with black highlights of spraypaint(your get the picture) IRON DUKE 4cyl, Project car for summer.
Mid Iowa Camaro Club Member
ICQ# 39648953
Http://screaminz.50megs.com
Thanks again
Nate.
Pics of the Z
ICQ# 39648953
there is a tech article written about this.
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series Muffler added to Unkown CatBack, Ported Intake
http://www.geocities.com/david_angel_16
- David
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The overhead console is a cool addition to thirdgen cars. They were produced from, I believe, 84-87. At any rate, there are two versions, a coupe and a T-top; they are not interchangeable. There should be two screws under the dome lens. Remove these, then for a coupe push the console forward and it will drop off the four mounting studs (if a t-top push toward the rear of the car). Once down, snip about six or eight inches of wiring harness off. The coupe version will have a carboard/foam reinforcement piece under the underliner. The holes were pre-drilled in my 85. Beyond that I can't say. Go to the tech article for more info.
JamesC
[This message has been edited by JamesC (edited November 24, 2001).]
JamesC
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I just bought an incomplete one from a junkyard for a T-top car and I had to push it forward.
John
G O D BLESS AMERICA
http://www.3rdgenformula.com
87 Formula 5.1 TPI Auto Modified (Yellow/Black)
87 Formula TPI (5 Speed) Yellow/Gray STOCK
14.8sec 1967 Buick Riviera
1990 Buick Riviera (driver)
83 Camaro
83 T/A
John
G O D BLESS AMERICA
83 Camaro
83 T/A
Yes...On T-top equipped cars you have to push forward to remove it and on the coupe version you have to push to the rear of the vehicle to remove it..I know,i just installed a T-top version yesterday on my 89Z.
Brent
Toys currently owned:
-91 MPFI Firebird
-97 Grand-Am GT
-96 Extreme Sonoma
-91 Suzuki GS500E
-89 Z28 Camaro(under construction)
-89 RS Camaro
Brent
-91 MPFI Firebird
-97 Grand-Am GT
-96 Extreme Sonoma
-91 Suzuki GS500E
-89 RS Camaro
Apparently I was giving instruction for installation.
JamesC
JamesC
1992 Trans Am
May 10, 2023 07:19 PM
