Can you fix a warped wrap around spoiler?
Old Dec 10, 2013 | 04:57 PM
Camrs89's Avatar
Car: 91 Formula, 79 Trans Am, 72 LeMans
Engine: 305 TPI, 6.6, 350 Pontiac
Transmission: T5, 3 speed, TH350
I know it's the incorrect one and I plan on getting the right 91/92 one at some point but until then, can you fix the sides of the wrap around spoiler? Mine looks warped? Not sure if you can see on the pic or not?
Old Dec 10, 2013 | 05:44 PM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Re: Can you fix a warped wrap around spoiler?
Search and you'll find many attempts with little success. There's an unpainted metal frame inside the rubber that eventually rusts, then bubbles up the rubber.
I think yours has the additional problem that it's not attached at the arms so it's really floppy.
To make it look better for a little while I would try bending the arms by hand to straighten it if possible and maybe epoxy it to the glass frame. The arm mounts for the correct wrap wing are different from the ones on that wing. Don't mess up the mounts on the glass frame since you need those for the correct wing. They may have been cut off by previous owner. You can also remove the third brake light and sell it. It's just screwed into the bottom of the wing. You may think it just looks better with no wing.
Old Dec 14, 2013 | 11:27 AM
a62belair's Avatar
Car: 88 Firebird, 87 Formula
Engine: 2.8, 5.0
Transmission: both 700R4
Axle/Gears: 3.42,3.45
Yes, I went with no wing... 40 lbs of junk on my formy when I bought it. I got a hatch from a Camaro with no spoiler, just rear defog...
gta892000
Aug 11, 2019 11:16 AM
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
CAMAROBEAV
European Region
Nov 18, 2015 06:41 AM
gta892000
Sep 16, 2015 12:40 AM
CAMAROBEAV
European Region
Sep 12, 2015 09:34 AM
