Coolant & Washer Bottle Retainers
Car: 1990 Iroc Convertible
I'm trying to restore my engine bay as best as i can. I bought a set (4) of coolant and washer bottle retainers along with the new bottles to go with it. I don't want to break anything, they look fragile. My question is how do these retainers go in? Any pictures would be appreciated. Thanks
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Coolant & Washer Bottle Retainers
Loosen the plastic screw. When the screw is tightened up it spreads the retainer at the bottom. I can't recall if you can get on the back side in the fender well to use a pair of pliers to squeeze in the retainer or not.
Yeah, I've tried to loosen and tighten and it doesn't give. The screw won't move, the whole thing just twists, feels like it will break. From the bottom looking at the bottom of the screw it looks like there is no hole for it to come out of,,, in or out. ??????????????
Engine: Lb9
Transmission: M20
Drill them out than and buy some gm 12337831
Engine: Lb9
Transmission: M20
http://www.ebay.com/itm/50-Front-Bumper-Push-Type-Clips-12337831-Pontiac-G6-/120601962786?pt=Motors_Car_Truck_Parts_Accessories&hash=item1c146fe922&vxp=mtr
Engine: Lb9
Transmission: M20
They should only be fifty cents to a buck at your local gm dealer. You might try using a pair of dykes and pry up on the screw. chances are the head may snap off though. Then just drill
Out the center and remove them.
Engine: Lb9
Transmission: M20
6 of one half a dozen of the other lol
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
I broke the screw and put a metal one through it instead if that cheap plastic. Done thanks.
Engine: 5.0 EFI
You should have gone with the plastic retainers.They seal much better,keeps the water(rain,puddles)from getting through,especially in that area.
I kept the retainer but I used a better screw. I left the plastic piece in between the fender and the bottle, fits snug.
Engine: 4++,350 & 305 CIs
If you are doing a 1000 pt restoration those aren't "correct" but they will work just fine.
The threads are really for removal only.
Put the clip in place and push the screw down, done.
[quote=TTOP350;5683747]If you are doing a 1000 pt restoration those aren't "correct" but they will work just fine. quote]
Not sure these are the "right" ones, but much closer.
http://www.clipsandfasteners.com/GM_...r_p/a13457.htm
Engine: 5.0 EFI
http://www.clipsandfasteners.com/GM_...h_p/a14011.htm
These are the correct ones.
Thanks for the info, I'm not doing a 1000 point restoration. Just an attempt to put together a nice enough driver.
[QUOTE=Joe Tag;5683767]
Those are very close. I'd run out and grab a pic but my lil guy is sleepn on me.
I just pointed out the difference in these for the future restoration searches.
Well toss him off and go get it, inquiring minds want to know!
Just playing, I have mine and know what they are. They just don't have them at that site. More like Manta's with the hex pin in them.
Engine: 5.0 EFI
TTOP,I think he's correct but they list it as a replacement for a different P/N.The pic I have in the beginning of this thread list as the replacement for the P/N 12337831 witch is the P/N in need.I overlooked that one when I ordered the retainers because that's what was listed.I'm going to order the ones he posted they look just like the ones in need.
Engine: 5.0 EFI
http://www.clipsandfasteners.com/Pro...uctCode=A20892
These are the ones I had ordered,I knew they were not the right ones but it says that they replace the P/N I needed.
Engine: 5.0 EFI
Gotta watch the length of the shaft, I know nothing about Metric
I'm white, sadly, this is not a issue I have to deal with....
When I go to the Junk yards, I grab a few buckets, put plastic clips in one, interior nuts/bolts in another, fuses, lights exterior all get their own place. Makes it easy to sort when I get home.
Engine: 5.0 EFI
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
For future reference:
I have NEVER had one of those "screws" unscrew on me (especially when they're older and more brittle). Just pull the things out like every other pop-it on the car. Pull out the "screw" and then pull out the rivet thing. Or you can cut the head off and then push the rest through the rivet a good portion of the time (some of the newer ones are closed on the end).
Yea!
