Whats the level of difficulty for diy on front bumper alignment
Old Jan 2, 2014 | 05:45 PM
topj's Avatar
Car: 88 Camaro IROCZ Convertible
Engine: 305 tbi
Transmission: auto
Heres a pic and the hood is popped up so its not that drastic but how difficult is it to attack this by myself ,im no dummy but no mechanic im familiar with tools
Whats the level of difficulty for diy on front bumper alignment-image-120301221.jpg
Old Jan 2, 2014 | 06:10 PM
Yenipenny's Avatar
Car: 92 RS Heritage
Re: Whats the level of difficulty for diy on front bumper alignment
I believe you have something more serious than an "alignment" problem. It appears to me that the car has been damaged for the gaps to be that far out.
In any case, it won't be a job for a novice.
Old Jan 2, 2014 | 06:41 PM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
There's something out of whack, but I think it might be only the fender. Probably bent in from poor jacking. You might be able to just Straighten the fender, but I think you will probably want to take off the bumper cover and see what's going on under there.
Look behind the fender and see if the brackets are bent. Look at the rear lower mounting bolt of the fender at the pinch weld, that's prob where it's bunged up.
Old Jan 2, 2014 | 07:35 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Check in the inside to see if there is any dents or folds on the front end radiator support. If there is then it may of had a wreck. Also if the po tried to jump a dip and came down hard on the front wheels‚ them there may be damage to the unibody. What year is it? I got a service manual that provides the measurements from certain points in the undercarriage. Measuring these sections will determine if you have serious body warpage.
Old Jan 2, 2014 | 08:08 PM
Mirror Image's Avatar
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
Yeah you may have some damage under there how does the bumper fit to the other fender it looks as if the bumper is to low and there is some adjustment so you may be able to loosen the bumper and move it up
Old Jan 3, 2014 | 12:36 AM
Here you go man. Dimensions of the undercarriage to see if theres any warping.
Attached Thumbnails Whats the level of difficulty for diy on front bumper alignment-measurements-f-body.jpg   Whats the level of difficulty for diy on front bumper alignment-measurements-f-body-2.jpg   Whats the level of difficulty for diy on front bumper alignment-measurements-f-body-3.jpg
Old Jan 3, 2014 | 06:59 PM
topj's Avatar
Engine: 305 tbi
Transmission: auto
THX for the support guys im gonna look into this issue this weekend, take a peep underneath
Old Jan 4, 2014 | 01:06 AM
1992 Trans Am
May 10, 2023 07:19 PM
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
mikey8494
Aug 22, 2015 07:57 PM
Wylecoyote08
Aug 22, 2015 01:58 AM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
