removing ground effects
Old Dec 6, 2001 | 11:00 AM
91rsrider's Avatar
ok i busted up both of my side rocker extensions and now they need to be replaced.what is involved in taking them off?i need to know because im going to try and find some in a junk yard so i dont have to spend 500 on a new set.is it possible to take them off without any special tools?thanks for the help!
~*Formerly known as 91rscruiser*~
-1991 camaro rs,dark red metallic,t-tops,stock 15inch rims,Z28 bowtie grille insert with driving lights
-L03 305,TH700R4,2.73's,only mods for now are...Flowmaster 80 series replacement muffler,accel wires and coil,14x3 open element with K&N,lockup switch at the track,and a catco cat.
-best 1/4 mile times to date:15.89@86 with a 2.26 60 ft
Old Dec 6, 2001 | 04:05 PM
toosloz's Avatar
take out the front emblem.....get those screws out....take out the screws underneath the car and in the door sill area
now....you have to remove the bottom rear peice behind your front seats to get at the last bolt.....it is right below your sail panels
Old Dec 6, 2001 | 08:45 PM
elizabeth's Avatar
If the damage isn't too great you can use flexible filler and a piece of screen. I put a layer of filler (very thin) and inbedded the screen. Then, add another coat on top. You can use glazing putty to smooth it up if sanding doesn't do the trick. Flexible body filler can be found at a auto paint store.
Old Dec 6, 2001 | 09:26 PM
Diabolical's Avatar
Car: 85 Trans Am WS6
Engine: 305HO L69
tools required to remove the rocker extensions are a phillips screwdriver, ratchet, 10mm socket, 13mm socket. when i did this, it took me like 2 hours to take them off, but that was because the car was on the ground with no wheels, and i had no idea that there were screws behind the emblem and a nut that you had to get from the interior. i would say it would take me like 15 minutes now that i know how to do it.
87 Camaro LT
bone stock lg4 w/ 700r4
1/4 mile: 35 seconds @ 50mph (or so it feels like it)
mods:
ground effects (in progress)
93 camaro seats (installed)
99 camaro center console (in progress)
85-87 iroc or 91-92 z28 rims (91-92 installed)
white 145mph iroc gauges (in progress)
Old Apr 24, 2006 | 07:29 PM
88 IROC CONVERT's Avatar
Car: 2002 zr2 Blazer 88 Iroc convertable
Engine: 305 T.P.I.
ground effects
[QUOTE=Diabolical]tools required to remove the rocker extensions are a phillips screwdriver, ratchet, 10mm socket, 13mm socket. when i did this, it took me like 2 hours to take them off, but that was because the car was on the ground with no wheels, and i had no idea that there were screws behind the emblem and a nut that you had to get from the interior. i would say it would take me like 15 minutes now that i know how to do it.
How do you take out the emblem just pry it out? I thought that was adhesive backed? how do you reinstall it? 3m tape?
Old Apr 24, 2006 | 07:36 PM
alkalore's Avatar
Car: 1992 Camaro RS
Engine: V-8
Transmission: 5-speed
As I recall, there are only 3 speed nuts holding the rocker gfx on beside the screws in the door sill area. Two are on the fender, which can be reached if the inner fender is removed, and the third nut can be removed said before underneath the sail panel, or if your flexible, by reaching through the black air vent in the door jam area.
Frozer!!!
Jan 19, 2024 04:55 PM
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
Mutillator
Oct 1, 2015 06:05 PM
mikey8494
Aug 22, 2015 07:57 PM
92firebirdchris
Aug 14, 2015 11:56 AM
