rim sizes
Old Feb 15, 2014 | 03:51 PM
strykerwolfe's Avatar
rim sizes
I have an 88 base firebird. want to replace the 15" camaro RS previous owner put on and was courios what sizes i could use
Old Feb 16, 2014 | 09:56 AM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
Re: rim sizes
15,16,17,18,19,and 20.in other words any wheel that will clear your brakes and the body.
Old Feb 16, 2014 | 11:21 AM
excessiveego's Avatar
Car: 1988 Base Coupe
Axle/Gears: 9 bolt w/ disk brakes - 3.70
Re: rim sizes
You can use whatever wheels you want as long as you buy tires accordingly. On a 16" wheel you would use a 245/55-16 tire but on a 20" wheel you would need to use a 245/35-20 tire
Old Feb 16, 2014 | 12:19 PM
Zane M's Avatar
Car: 1991 GTA
Engine: LB9
Re: rim sizes
Also keep in mind, as you start getting into the sizes above 16", you may have to run some type of spacer depending on the offset and backspacing available in the particular wheel you want to run.
Old Feb 16, 2014 | 05:21 PM
Re: rim sizes
thanks for the input guys
Linson
Sep 21, 2015 01:08 PM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
Brian Anderson
Wheels and Tires
Sep 12, 2015 06:12 PM
dennisbernal91z
Wheels and Tires
Sep 12, 2015 12:28 AM
m00n420
Sep 11, 2015 02:39 PM
