faded t-top edge
Old Feb 17, 2014 | 07:30 PM
85ttopsz28's Avatar
Car: '85 camaro z/28
Axle/Gears: stock
faded t-top edge
Im thinking about replacing the t-top drip seals on my '85 camaro and i also wanted to address the t-top edge that is faded (all camaros it seems like). I searched but couldnt find anything. Im thinking a black spray paint and a clear coat. Does anyone have ideas/suggestions or experience re-doing these?
Old Feb 17, 2014 | 08:01 PM
Hal87's Avatar
Car: '84 Firebird TA & '87 Camaro LT
Engine: 350 V-8 & V-6
Axle/Gears: 3.23 & 3.42
Re: faded t-top edge
I just went over mine with some steel wool, cleaned them good, masked off the glass and spray painted them. Has stood up well.
Old Feb 17, 2014 | 08:17 PM
akanitro's Avatar
Car: 1989 GTA, 2004 Z06, 2008 Expedition
Engine: L98, LS3, 5.4L
Transmission: 700R4, MN6, Auto
Axle/Gears: 3.23, 3.42, ?
I was thinking of using vinyl wrap in matte black to give hem the original look. Just an idea.
Old Feb 17, 2014 | 08:19 PM
85ttopsz28's Avatar
Axle/Gears: stock
what kind of paint did you use and how well did it match with the other trim/weatherstripping?? any clear coat? thanks a lot.
Old Feb 17, 2014 | 08:36 PM
mikesz1984's Avatar
Car: 1984 z28
When i redid mine i used a marhyde product called black satin. I found it matched the the other trim pretty decent
Old Feb 17, 2014 | 08:43 PM
82tarecaro's Avatar
Sand them, hit them with an adhesion promoter, prime, then paint with SEM trim black. It will hold up well.
Old Feb 18, 2014 | 12:27 AM
Hal87's Avatar
I used the SEM trim black, same as several others, didn't use a clear coat, probably should have.
Old Feb 18, 2014 | 09:15 PM
85ttopsz28's Avatar
Axle/Gears: stock
thanks guys!!!
Old Feb 18, 2014 | 09:24 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Do it the easy way - plastidip. Should have a nice flat black appearance and protect the metal underneath just fine. I've had it on my hood for over a yea,r the stuff will ever so slightly fade over years, but it's super easy to just spray a new topcoat of the stuff on and it's good as new. Removable later if you get an oppurtunity to really paint it. I've heard of guys, for example, plastidipping hatch glass trim.
Old Feb 19, 2014 | 04:06 PM
cdoyle's Avatar
I ended up rattle can black/clear on mine
It's been holding up pretty well, it's going on 3 years I believe.
F-body-fan
Jan 12, 2023 01:49 PM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
gord327
Oct 3, 2015 01:25 PM
thejimsterz28
Sep 30, 2015 08:52 PM
