flat black or gloss black (headlight area)
Car: 92 camaro RS
Engine: vortec 350/396
Painting my front bumper tomorrow. Im still trying to decide if I should do the headkight area gloss black or flat black. I have the front bumper grill insert that is all fkat black with the word camaro in the middle and the letters are white. Found that piece in local junkyard. But unless I paint that grill piece gloss black Iwas thinking it may looks a little odd? Need oppinions. Also does anyone know what to use for the headlight area if I do flat black. I know its just not flat black paint. Its something a little more durable I just dont know what it is
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: flat black or gloss black (headlight area)
Originals were semi-gloss or gloss... most people seem to agree they should be semi-gloss but there are exceptions from the factory.
I think it's probably better to go semi-gloss/flat unless you have buckets that are super straight and not warped like most of these are.
That said, like I mentioned, the factory often sent out semi-gloss buckets with the shiny black grille, but the fact is those black grilles may be shiny, but they are nowhere near as shiny as, for example, black paint. They are not mirrors. Semigloss or even flat (like my car with the plastidip) doesnt look out of place at all.
I went with gloss black on mine, it matches the blisters on the hood.
I think it looks great, and really glad I went this route
Have some more pictures here
https://driiive.com/chrisfromwa/1984...-Ghetto-Ride-/
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
All the ones I remember were semi gloss I almost bought a new red 85 Z28 Tops and all
Car: 91 rs camaro hard top
Engine: 350 vortec
Transmission: 5 speed. T5
Axle/Gears: 3.70 gear 9 bolt posi. disc brakes
imo i think if your bumper is warped a little, id go with semi-gloss. but if not id go gloss.
cdoyle- your car looks great!
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
It depends on the overall paint. If the car is a extremely high gloss with a high gloss bowtie insert like mine then I decided to go high gloss.On some a very high gloss might seem out of place. That goes both ways. Anything other then high gloss would seem out of place to me on my car.=
Transmission: 5-Speed Manual
Go With The Factory Finish,If Your Looking For The Originality Look.
Engine: LQ4 ls 6.0
Car: 92 camaro RS
I have the same grill as "mirror image" I think ill do gloss black. It would look better with the car. Its medium quasar blue metallic and we put a lot of clear on the car. I think the gloss black will look good. I might have to gloss blacl the grill
These cars came from the factory with semi-gloss on the buckets. I elected to gloss mine with clear so that it wouldn't oxidize like the original semi-gloss paint.
No there weren't. If they were black from the factory, they were a satin black. There was not a flat black or a gloss black from the factory. The front grill area changed to gloss finish from satin in 1990 or 1991. I don't remember.
Engine: LQ4 ls 6.0
All the ones that I remember had just enough shine that you could see the head light in the black and that wouldnt be satin satin is just about as flat as flat
Car: 86 Camaro SC
Engine: 5.3L LM7
Transmission: TH350
flat, matte, eggshell, satin, silk, semi-gloss, high gloss. These terms are not standardized, and not all manufacturers use all these terms.
Tomato, tomahto. Ones mans satin is another mans flat and another mans matte. Specular reflection is much more complicated than that.
I'm sure GM had a paint code for the buckets. It's likely unavailable now. I think they look better painted the color of the car so as not to look like a gothic, manic depressive. :P
Satin black or Semi gloss, whatever you decide to call it. It is not high gloss on any factory produced Z28 or Heritage Edition.
Do a search on the History forum and you will see exactly what cars got what. You may even find the SEM color code for the exact finish.
Engine: LQ4 ls 6.0
Maybe this will help I mix my own black and you can make it as flat as you want here is the standard for black http://en.wikipedia.org/wiki/Glossmeter
Car: 1992 Camaro RS
Did we as a community ever establish for sure that black cars got semi-gloss buckets? I remembered a thread addressing it but I dont remember what the conclusion was and I couldn't find it.
Black car with "non-gloss" buckets
https://www.thirdgen.org/forums/hist...t-pockets.html
BTW, I reread my post above and it doesn't say anything about the non Z28 cars. The non Z28 and non Heritage Edition cars had the headlight buckets painted the same color as the car. In the case of a black car, they were painted gloss black to match the car. That's the only time the buckets would be high gloss.
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
Mine are painted with............
http://www.globalindustrial.com/prod...FY1QOgodXCUAYw
I have also used Duplicolor on my t-tops and it matches perfectly...
http://www.carid.com/universal-paint...FQHNOgodIhgAjg
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
I used semi gloss tremclad on mine LOL. It actually turned out pretty good.
Car: 1969 RS Z28 X33 Norwood built
Engine: 383 Stroker
Transmission: T10 4 speed
Car: 91 Camaro RS 305TBI
Transmission: 7004
Axle/Gears: stock posi .373
i think it should match the grill insert.. i mean this is totally just my opinion. i've been debating this since i carbon wrapped my grill.. i think i'm going to wrap my buckets in carbon too, since my hood is also going to be carbon
Car: 1992 Camaro RS
I liken it to painting steel wheels an aluminum color and saying it's aluminum...
But theres all kinds of form over function things on these cars that we give a free pass so I dont know.
Car: 1992 Camaro RS
You may have seen a berlinetta with black buckets. I dont know if ALL of them got black buckets, but I know at least some of them did.
Transmission: 7004
It's conceivable that your grille is carbon fiber, but I dont think anyone is going to believe your front clip is carbon fiber. It gets into this weird sort of....
good point.. i didn't think of it that way.. maybe i will go with just painting the whole clip one color..
Car: 1984 z28
My 1986 sc had factory original black buckets. I was the second owner and i know the person who had it before me. Lol i actually saw it on the lot and told the guy about the car.
1992 Trans Am
May 10, 2023 07:19 PM
LT1Formula
Nov 16, 2015 01:13 PM
